water cooling gpu required reference card? - Overclock.net
post #1 of 3 Old 08-16-2013, 01:50 AM - Thread Starter
333mhz
xconwing's Avatar
Quoted: 0 Post(s)
Liked: 1
Hello fellows OC,
My first question is as titled, does water cooling gpu required reference card? If so, how can you tell reference card from non-reference by look at the specs (such as on Newegg specs). Secondly, how effective is universal gpu waterblock?
Thanks,
X
xconwing is offline
post #2 of 3 Old 08-16-2013, 01:53 AM
Case Modder
Ardalista's Avatar
Quoted: 0 Post(s)
Liked: 47
Send a message via Skype™ to Ardalista
You don't always require reference cards, it really depends on the block manufacturer as to what cards they choose to support.
EK has a good configuration guide and a list of supported cards and recommendations on what blocks can work with different models / revisions of cards.
generally most people look for a block they like and see if it's still in production and buy it and then get the card to suit it.
Ardalista is offline
post #3 of 3 Old 08-16-2013, 03:13 AM
Intel Overclocker
glinux's Avatar
Quoted: 0 Post(s)
Liked: 82
Send a message via Skype™ to glinux
I do it either that way or double check through EK's http://www.coolingconfigurator.com/ which lets you know if their block works on the gpu you are looking to buy.
DON'T WORRY! I didn't brick my phone...oh wait...give me an hour I'll figure it out.
RIP Dublin Dr. Pepper 1-11-12
glinux is offline
