How-to: EVGA GTX 780 Classified Hydrocopper Installation - Overclock.net
post #1 of 9 Old 08-22-2013, 09:27 PM - Thread Starter
Lord Odin's Avatar
Quoted: 0 Post(s)
Liked: 1
Here's a vid for people who may have trouble with adding a Hydrocopper waterblock to their 780 Classified. Hope it helps.
Poursang likes this.
Lord Odin is offline
post #2 of 9 Old 08-22-2013, 09:44 PM
kimoswabi's Avatar
Quoted: 0 Post(s)
Liked: 21
Simple and easy. Love the toothpick idea. It would have also been great to see how the video card & Hydrocopper looks like in action. Great tutorial!
kimoswabi is offline
post #3 of 9 Old 08-23-2013, 07:33 AM
PC Gamer
clone38's Avatar
Quoted: 0 Post(s)
Liked: 1
Cant you put the backplate on with the shim first like what you can do with the 680 Classified.
Corsair 900D watercooling build incoming.
clone38 is offline
post #4 of 9 Old 08-23-2013, 09:08 AM - Thread Starter
Lord Odin's Avatar
Quoted: 0 Post(s)
Liked: 1
Not exactly because the first long screw needs to go in before the backplate goes on or else it gets covered up. It's wierd they didn't make a hole for it because that would be easier.
post #5 of 9 Old 08-23-2013, 10:09 PM
Quoted: 0 Post(s)
Liked: 1
Nice video, although I would have liked to have seen the GPU shim installed.
DarkStarX is offline
post #6 of 9 Old 08-31-2013, 11:28 PM - Thread Starter
Lord Odin's Avatar
Quoted: 0 Post(s)
Liked: 1
Actually, the shim was installed. That's where the toothpick trick comes into play and prevents it from slipping around beneath the backplate.
post #7 of 9 Old 09-03-2013, 05:45 AM
Quoted: 0 Post(s)
Liked: 1
So the shim is under the backplate or on the front?
post #8 of 9 Old 09-03-2013, 07:55 AM - Thread Starter
Lord Odin's Avatar
Quoted: 0 Post(s)
Liked: 1
It's between the board and the waterblock. It needed to go on first because there is a screw that needs to go in before the backplate is in installed.
post #9 of 9 Old 09-03-2013, 11:00 PM
Quoted: 0 Post(s)
Liked: 1
Okay, thanks.
I'm considering picking up a couple of these, I was planning on waiting until spring and getting them when I get everything for the rig I am going to build then and I had planned on getting the ones with the waterblock already attached, but I've started considering grabbing a one of the air cooled ones now and then buying the waterblock for it when I order a second water cooled for the full build in the spring.
My current rig has a i7-930 @ 3.4GHz and a Radeon HD 5970 2GB. I currently only use a single 24" 1920x1080 monitor in the spring I want to pick up a couple more 24" LCDs to go with it, or maybe a single 27-30 inch monitor with a res higher then 1080p
