Cooling 4770K & 2x 780Ti - Overclock.net
post #1 of 5 Old 11-20-2013, 08:29 PM - Thread Starter
I have many leatherbound books
Quoted: 0 Post(s)
Liked: 276
First of all, I'm aware that blocks aren't really available for the 780Ti yet. However, this planning is for a build that should be completed around Christmas.
I'm planning on going with 2 EK 480XT rads and either a single MCP655 or MCP35x paired with some EK 780Ti blocks (when they come out) and an EK Supremacy. I've got a pretty good feeling that my proposed loop will handle the thermal load, but just wanted to make sure.
Your input is appreciated!
kidwolf909 is offline
post #2 of 5 Old 11-20-2013, 08:31 PM
Folding Fanatic
lowfat's Avatar
Quoted: 0 Post(s)
Liked: 452
Really depends on your fans and what speed you'll run them at and how much you'll be overclocking them. But for most part it should be fine.
lowfat is offline
post #3 of 5 Old 11-20-2013, 09:02 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 276
Thanks lowfat! I'm planning to run medium speed fans in a push-pull configuration... there should be plenty of airflow. I am anticipating running the 4770K up to about 4.5GHz. but the 780Ti's will be near stock.
post #4 of 5 Old 11-20-2013, 09:07 PM
Folding Fanatic
lowfat's Avatar
Quoted: 0 Post(s)
Liked: 452
lowfat is offline
post #5 of 5 Old 11-20-2013, 11:18 PM
Intel Overclocker
IronDoq's Avatar
Quoted: 0 Post(s)
Liked: 12
That will definitely be sufficient.
This, pretty much. I run a 1.4v 3770k and two 780s @ 1.2v and 1241 mhz all off of a 60mm 420 and 80mm 240. With all my fans at 1000 rpm the GPUs never top 40C and the CPU never goes above 65. You'll be more than fine, you'll have amazing temps!
IronDoq is offline
