OCN Aquaero Owners Club - Page 801 - Overclock.net
 1Likes
post #8001 of 11421 Old 07-06-2016, 09:09 AM
WaterCooler
GTXJackBauer's Avatar
Quoted: 0 Post(s)
Liked: 18
Here's a nice Delta-T chart I grabbed a while back from Swiftech.
Have you increased your fans to see the temp differences? Play around with that and get comfortable with what you want and make sure your pump flow is in the 1.0-1.5 GPM sweet spot.
ll Corsair 900D ll Intel Core i7-5930K @ 4500.0MHz on HWBOT ll EVGA X99 Classified ll Crucial Ballistix Sport 2400MHz 16GB ll Aquaero 6 XT ll EVGA GTX 780 Classified 3GB Hydro Copper (x2 in SLI) ll Samsung XP941 512GB PCI-E 2.0 x4 M.2 SSD ll WD VelociRaptor 10k RPM 300GB - x2 ll WD Black 1.5TB - x2 ll Toshiba 3TB ll Corsair AX1200i ll ASUS VS248H-P 24" 2ms LED - x3 - Nvidia Surround ll Bose Companion 5 ll
ll Custom Swiftech XL ll Black Ice SR-1 240mm+360mm+480mm ll Helix120 (PWM) ll Swiftech Maelstrom-35X2 ll Aqua Computer High Flow Sensor ll Phobya Temp Sensor Coupler ll Bitspower Compression Fittings (1/2 ID 3/4 OD) ll PrimoChill Advanced LRT 1/2 ID 3/4 OD (Bloodshed Red) ll
GTXJackBauer is offline
post #8002 of 11421 Old 07-06-2016, 10:40 AM
ruffhi's Avatar
Quoted: 0 Post(s)
Liked: 103
What is the solution to this issue with the thingo and the passive heat sink?
I've emailed AquaTuning USA and will see what they say. That little thingo is stopping the passive heat sink from bedding down. I am pretty sure I saw this reported somewhere else.
DerComissar likes this.
Build Logs - Complete                                                      Build Logs - Active
Home Server ... Take III                                                      'Liquorice Allsorts' - 'C-Sweet' Thought Log coming to life ... CaseLabs S5 + Pedestal
'C-Sweet' - a 'Thought Log'                                                   'HTPC Builds into small cases' - Antec VSK2000-U3 and Fractal Design Node 202
'Set and Forget' ... a NAS in a CaseLabs Nova X2M (NAS moved into bigger box ... Home Server III)
HTPC - Silverstone Tek ML07B with Cryorig C1 CPU cooler
NAS - Running FreeNAS in a Cooler Master 915R (NAS moved into Nova Case)
Other Stuff
ruffhi is online now
post #8003 of 11421 Old 07-06-2016, 12:00 PM
WaterCooler
Ironsmack's Avatar
Quoted: 0 Post(s)
Liked: 50
Originally Posted by Vindicare View Post
I have increased the max temprature to 20ºc, delta temprature during normal load is something like 8ºc and fans are at below 50%.
i just dont know what the correct numbers should be, i read that equal or below 10ºc delta temprature is good.
There's no correct numbers. I view the below 10C delta a guideline and according to your preference. If it falls within that delta, you're good man thumb.gif .
My delta with my computer is between 6C (no load) to 8.5ish C (with load), with my fans running (below 1500 RPM).
I set my loop up based on my temp preference and noise tolerance.
Gaming Rig:
- (2) Swiffy MCP35x, (2) Aphacool UT60 480 rad, (1) 360 HWL GTX, (1) 240 HWL GTS, Heatkiller IV, 5930k @ 4.4 GHz, Asus X99 Deluxe II, NVidia 1080 w/ EK GTX WB 2050/5500, 240 GB Intel 530, 500 GB Samsung EVO 850, (5) 3 TB Toshiba Drive, EVGA 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.3Ghz, Asrock Z97 Pro 4, D5 vario w/ EK top, 480 XSPC RX, 240 HWL GTX, Asus 290 w/ XSPC WB 1000/1300, Crucial 128 GB SSD, 2TB WD Green, 5TB Toshiba HD, 2TB Samsung F4, 6TB & 8TB HGST Desktar, Enthoo Primo, Corsair HX620 PS, Win 10 Pro
Ironsmack is offline
post #8004 of 11421 Old 07-06-2016, 12:45 PM
Waterbug
Gabrielzm's Avatar
Quoted: 0 Post(s)
Liked: 399
If I recall correctly you can push it sideways a bit to make room for the heatsink and will end up been between the side panel and the heatsink. Send a message to Shoggy.
Gabrielzm is online now
post #8005 of 11421 Old 07-06-2016, 12:53 PM
ruffhi's Avatar
Quoted: 0 Post(s)
Liked: 103
Thx Gabrielzm ... PM away. I tried pushing it out of the way but it still caught on the heatsink and squished the connectors.
Other Stuff
post #8006 of 11421 Old 07-06-2016, 01:01 PM
Waterbug
Gabrielzm's Avatar
Quoted: 0 Post(s)
Liked: 399
mmmm. Found an earlier discussion about it:
http://www.overclock.net/t/1474470/ocn-aquaero-owners-club/3110#post_23420130
DerComissar and ruffhi like this.
post #8007 of 11421 Old 07-06-2016, 01:04 PM
ruffhi's Avatar
Quoted: 0 Post(s)
Liked: 103
Thx Gabrielzm. (+REP). I thought I had seen something earlier (like in about the last 8 months) and (IIRC) the general suggestion was to desolder the brown thing and resolder it so it isn't so tall / proud. Unfortunately, I don't have those sort of solder skills.
Other Stuff
post #8008 of 11421 Old 07-06-2016, 01:25 PM
Overclocker
jsutter71's Avatar
Quoted: 0 Post(s)
Liked: 47
Originally Posted by Shoggy View Post
As already written in the e-mail I am pretty sure that your pump adapter is not configured the right way. You have to insert a sealing screw (included) into the outer thread because otherwise you will have an open hole between the base and the adapter. Of course the water will easily run out there as soon as you fill some in.
The hole in the half-moon Plexiglas part has no usage for this product variant. The aqualis XT variants (stand alone) use this hole to move water into a side channel for the fill level sensor.
You are the MAN Shoggy:-)
Asus X99-E WS USB 3.1
Intel Core i7-6950x @ 4.4GHz
Dual Titan XP SLI
64 GB G.SKILL TridentZ Series DDR4 3200 CL 14
Samsung 1 TB 960 pro, 2 Samsung SM951 NVMe 512GB RAID 0 VIA HighPoint SSD7101A
My System
http://www.overclock.net/lists/display/view/id/6611645
jsutter71 is offline
post #8009 of 11421 Old 07-06-2016, 01:34 PM
DerComissar's Avatar
Quoted: 0 Post(s)
Liked: 215
Holy moly.
Looks like the Diva ground, filed, dremelled, whatever, the notch in the heatsink a bit more, to clear it.
Imo, I'd rather do that, than desoldering/resoldering that part.
I just recently bought my AQ6, and the heatsink, so I'll take a look at it tonite to see if it has that issue as well.
DerComissar is offline
post #8010 of 11421 Old 07-06-2016, 02:26 PM
Graphics Card Aficionado
Dagamus NM's Avatar
Quoted: 0 Post(s)
Liked: 70
That is a nice delta. Just tune it so that you maintain the delta you want with an acceptable fan noise level. There is no single delta you need to maintain, if you load your cpu and gpu and still keep it low then you have a sweet spot and don't need more fan.
Dagamus NM is offline
