Lamptron fan controller and temperature sensor - Overclock.net
post #1 of 5 Old 09-21-2015, 01:40 PM - Thread Starter
Methodical's Avatar
Quoted: 0 Post(s)
Liked: 19
I am about to water cool my cpu and gpu and wanted to know which G1/4 sensor is compatible with the Lamptron FC5 V2 fan controller. I figured I'd try and use what I have. Has anyone used this controller to monitor water temperature in their loop? If so, please chime in I'd appreciate it?
Thanks....Al
"Remember, never be afraid to try something new, amateurs built the Ark, professionals built the Titanic"
4.7ghz
Firestrike
Build in Progress
Methodical is offline
post #2 of 5 Old 09-21-2015, 02:06 PM
Jakusonfire's Avatar
Quoted: 0 Post(s)
Liked: 552
They all use the standard sensor type so any brand will be fine.
Except that is, for Koolance. They used to make some different sensors. If it says 10K in the description or product name it'll be fine.
Jakusonfire is offline
post #3 of 5 Old 09-21-2015, 02:50 PM - Thread Starter
Methodical's Avatar
Quoted: 0 Post(s)
Liked: 19
Thanks. I wasn't sure and what makes it worse is some of these companies don't have phone numbers to call for help.
4.7ghz
Firestrike
Build in Progress
post #4 of 5 Old 09-22-2015, 12:59 AM - Thread Starter
Methodical's Avatar
Quoted: 0 Post(s)
Liked: 19
I see that Performance PC has the Koolance temperature sensors (10K ohms), but it states that it only works with Koolance products which use 10K Ohm @25°C sensors. Although Koolance states this, it's 10k ohms will this be ok?
Edit: never mind I found the Bitspower which can be used with any controller.
Thanks
4.7ghz
Firestrike
Build in Progress
post #5 of 5 Old 09-24-2015, 12:43 AM
Quoted: 0 Post(s)
Liked: 552
I think maybe the Koolance stuff uses a proprietary or different connector than all the common ones do. All the normal temp sensors are 10k at 25c
Methodical likes this.
