Thinking About Switching to PETG Hard Tubing - Overclock.net
post #1 of 8 Old 12-23-2015, 02:34 PM - Thread Starter
Commodore 64
chuckfarnham's Avatar
Quoted: 0 Post(s)
Liked: 2
So I am thinking about making the switch to PETG hard tubing in my rig. I did the soft tubing about 9 months ago and ready to try something new. Does anyone have any advice or suggestions? I am still working up ideas on how I would run the tubing. Not sure if I just want to plan it out similar to how the soft tubing is now. Or come up with a completely new layout?
Any input is greatly appreciated!
chuckfarnham is offline
post #2 of 8 Old 12-23-2015, 11:13 PM
Radnad's Avatar
Quoted: 0 Post(s)
Liked: 178
Imo keep it the exact same layout. Do you plan on bending or using elbows for turns?
Radnad is offline
post #3 of 8 Old 12-24-2015, 06:31 AM - Thread Starter
Commodore 64
Quoted: 0 Post(s)
Liked: 2
I want to try my hand at bending. Plus it will help keep the cost down with all the fittings. I grabbed a few tubes to start practicing before the real deal.
I also want to get away from the pastel coolant. Thinking about going with a UV blue. Any thoughts on coolant colors that will match black and gold?
post #4 of 8 Old 06-04-2016, 12:18 PM - Thread Starter
Commodore 64
Quoted: 0 Post(s)
Liked: 2
Well I went for it!!
post #5 of 8 Old 06-04-2016, 05:33 PM
WaterCooler
RavageTheEarth's Avatar
Quoted: 0 Post(s)
Liked: 144
Looks great!
Hardware
Gigabyte G1 Gaming 7 Z170 Motherboard - Intel i7 6700k @ 4.7Ghz (1.38v) - G.Skill Trident Z 3400Mhz DDR4 - Gigabyte Aorus 1080 Ti @1.093v 2126/12.2Ghz - Dual Samsung 500Gb SSD's - Evga G2 1300w PSU - Phanteks Enthoo Primo
Dual MCP655's - Ek X-Top 150 Reservoir/Pump Top -EK D5 Pump Top - Alphacool XT45 420mm Radiator - Alphacool Monsta 360mm radiator - Alphacool UT30 240mm radiator - Monsoon Fittings - EK Gigabyte G1 Gaming 7 Monoblock - EK-FC1080 GTX Ti Aorus - Acetal+Nickel - EK-FC1080 GTX Ti Aorus Backplate - Black
RavageTheEarth is offline
post #6 of 8 Old 06-05-2016, 08:54 PM
WaterCooler
FluidicFluids's Avatar
Quoted: 0 Post(s)
Liked: 0
very good job!
FluidicFluids is offline
post #7 of 8 Old 06-05-2016, 09:47 PM
Radnad's Avatar
Quoted: 0 Post(s)
Liked: 178
Incredibly awesome job, you totally outdid yourself! Might even take inspiration from you in my Skylake build in an F31. Make sure you post it in the water cooling club if you haven't already. thumb.gif
Radnad is offline
post #8 of 8 Old 06-10-2016, 07:54 AM
Ypsylon's Avatar
Quoted: 0 Post(s)
Liked: 33
Looks nice.
One thing of caution however. While PETG has many advantages it has one annoying feature. Bluish tint will be visible over any coolant which is not blue or green. One of the reasons why I moved away PETG and went to PMMA. It annoyed me greatly that my yellow coolant was a bit green when looking at pretty much every angle. And PMMA is much sharp for colors than hazed PETG. With pastels it's probably less of an issue, but still I think it's worth to underline.
Ypsylon is offline
