Why you should probably not buy a CLC cooler - Page 48 - Overclock.net
post #471 of 487 Old 08-29-2017, 05:57 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Originally Posted by Dasboogieman View Post
I opened up a H80i recenetly and I was completely baffled at the component selection. They really designed it for planned obsolescence, that thing has an Aluminium radiator coupled with a Copper plate. Legit this thing is rigged to blow once the corrosion inhibitors stop working after 3-4years and if you refill without the same corrosion inhibitors, the thing will die within months.
If you want a real shocker, time how long it takes to pump a liter of water. biggrin.gif
If you do test pump flow, please let me know what you get. Asetek does not release that information. tongue.gif
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #472 of 487 Old 08-29-2017, 10:12 AM
Dasboogieman's Avatar
Quoted: 0 Post(s)
Liked: 105
Umm it took about 3 minutes to fill a 2L Ice cream container when I was flushing it. Granted mine was on the brink of death but dayumm.
Dasboogieman is offline
post #473 of 487 Old 08-29-2017, 10:34 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
That's about 30 liter/hour. Here is a chart I've been working on showing AIO and CLC pump specs.
doyll is offline
post #474 of 487 Old 08-29-2017, 02:56 PM
garyd9's Avatar
Quoted: 0 Post(s)
Liked: 20
Only to show a baseline and contrast, it might be interesting to add lines at the bottom showing a standard (not custom top) D5 and DDC pump. I think people might be shocked to see the massive flow/pressure differences between CLC minipumps and the real things.
garyd9 is offline
post #475 of 487 Old 12-17-2017, 10:36 AM
shilka's Avatar
Quoted: 0 Post(s)
Liked: 2696
Came across this so any chance this can be added to the OP
https://www.gamersnexus.net/guides/2122-who-actually-makes-liquid-coolers-oems
The only brand that seem to be missing is Be Quiet so is there a better database somewhere else on the web?
Also Asetek based coolers should be avoided like the bubonic plague as they are some of the worst patent trolls around
The graph posted above by doyll should also be added
shilka is offline
post #476 of 487 Old 12-17-2017, 10:58 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
I made a chart with additional data and gamersnexus data:
http://www.overclock.net/t/1491876/ways-to-better-cooling-airflow-cooler-fan-data/60_20#post_23781217
Sure wish I could find more data about Asetek, Apaltek and CoolIT pumps and their specifications.
doyll is offline
post #477 of 487 Old 12-17-2017, 01:04 PM
Intel Overclocker
Quoted: 0 Post(s)
Liked: 367
Yeah, it's so weird that they won't publish any specs.....almost like they have something to hide..... biggrin.gif
I had the specs on the first Apaltek released by Silverstone. Not great, but not as horrifically bad as what we have seen measured on Asetek and CoolIt units.
ciarlatano is offline
post #478 of 487 Old 12-17-2017, 01:26 PM
Forum Manager
Quoted: 4 Post(s)
Liked: 1329
I personally love my Enermax Liqtech TR4, Great peice of kit for the money. There are disadvantages with any cooler type but I think CLC is just fine so long as you understand the limitations and have done the correct homework prior to committing to it.
Welcome to Overclock
Chimp Challenge 2 x Participant  100 Million+ Folding at Home points  Overclock.net 10 Year Member
ENTERPRISE is offline
post #479 of 487 Old 12-17-2017, 01:43 PM
Overclocker
Cryptedvick's Avatar
Quoted: 0 Post(s)
Liked: 263
Cal me old fashioned, but in my opinion, a good tower with a push/pull setup is the best way to go. Had a TRUE with a couple of 3k Kazes (with a fan controller for obvious reasons) that kept my CPU nice a cold. Now running this NHU12P SE2 with the same 2 Kazes that have been going for years with no problem and great temps.
R.I.P. Daniel Costin
It's galaxy, he has a better shot getting an RMA from Jesus himself haha <-lachen.gif
Chimp Challenge 2 x Participant  2 Million+ Folding at Home points
Cryptedvick is offline
post #480 of 487 Old 12-17-2017, 01:46 PM
ThrashZone's Avatar
Quoted: 3 Post(s)
Liked: 29
HI,
Yeah I was so close to buying a Kraken x62 and thankfully they were sold out at my local micro center
I read on 3Dguru they actually require using facebook and something else to save a lighting profile lol biggrin.gif
That it self was a deal breaker but all of the bad reviews with dead pumps was also eye opening :shock:
Either way sort of sad the new EK offerings grew their 280 rad size a couple inches looks like frown.gif
Bummer they sized it out of my case :/
EK 280 performance rad size is perfect.
https://www.ekwb.com/shop/ek-mlc-phoenix-280-radiator-core-module
ThrashZone is offline
