980ti EVGA SC waterblock help. - Overclock.net
post #1 of 18 Old 08-18-2016, 05:59 AM - Thread Starter
Alexyy's Avatar
Quoted: 0 Post(s)
Liked: 2
Hey, I've got myself a EVGA 980ti SC that I'm wanting to watercool, when searching for a GPU block, I ran into some walls...
It turns out my GPU isn't compatible with any full cover blocks as it uses a slightly different EVGA PCB variant, Pictured here.
Here's my GPU,
is this true? am i fked?
Alexyy is offline
post #2 of 18 Old 08-18-2016, 06:48 PM
Quoted: 0 Post(s)
Liked: 19
This is an SC with a reference cooler on it, so no the SC is a reference PCB. You will be fine.
https://www.amazon.com/EVGA-GeForce-Cooling-Graphics-06G-P4-4992-KR/dp/B00YDAYOJG
mtrapuzz is offline
post #3 of 18 Old 08-18-2016, 06:50 PM
SFF Enthusiast
ghostrider85's Avatar
Quoted: 0 Post(s)
Liked: 329
I have two 980 ti waterblocks from swiftech if you live anywhere near LA.
1 Million+ Folding at Home points
ghostrider85 is offline
post #4 of 18 Old 08-19-2016, 06:37 AM - Thread Starter
Alexyy's Avatar
Quoted: 0 Post(s)
Liked: 2
Alexyy is offline
post #5 of 18 Old 08-19-2016, 06:40 AM - Thread Starter
Alexyy's Avatar
Quoted: 0 Post(s)
Liked: 2
It says it's not compatible right here.
http://image.prntscr.com/image/c4131ebb0a58491f8308e26bd1e5099a.png
Alexyy is offline
post #6 of 18 Old 08-19-2016, 07:00 AM
PC Gamer
slickwilly's Avatar
Quoted: 0 Post(s)
Liked: 241
EVGA change the PCB and cooler design on a few of their 9 series cards, I have a GTX970 FTW+ ACX2.0 and only one company makes a cooler for it,Aquacooling, their NaxXxos line covers quit a few cards that no one else is making a block for.
Diablo 3-wolff#1279
Chimp Challenge Participant  1 Million+ Folding at Home points
slickwilly is offline
post #7 of 18 Old 08-19-2016, 07:58 AM
Quoted: 0 Post(s)
Liked: 19
I would call EK and double check with them, but I believe the reason you don't see a full cover block is because you need to buy a Titan X block. The Titan X card came out before the 980ti and because the PCB is the same layout, I don't think they ever made blocks specifically for the 980ti. Just go in and select the Titan X SC and it all should fit your 980ti.
mtrapuzz is offline
post #8 of 18 Old 08-19-2016, 08:50 AM
WaterCooler
Quoted: 0 Post(s)
Liked: 14
This. I think EK only made blocks for custom PCB 980 Tis. Cards with reference PCBs can use the Titan X block.thumb.gif
fisher6 is offline
post #9 of 18 Old 08-21-2016, 05:17 AM
Pej06's Avatar
Quoted: 0 Post(s)
Liked: 1
The EK Titan X block is fully compatible with your card..OK with all the GTX 980 Ti SC serie from EVGA.
https://www.ekwb.com/configurator/waterblock/3831109830550
The problem is different for the FTW...wich has a different PCB..No problem with your SC thumb.gif
I've got one Nickel Plexi...Never used......From France ,if you want to save some money.
Pej06 is offline
post #10 of 18 Old 09-28-2016, 11:33 AM
DixonCider's Avatar
Quoted: 0 Post(s)
Liked: 0
I have three of the same card, and I ran into the issue you are having. EK isn't very clear about the TitanX block being compatible with this card or not. In some places it says it is, in others it says it isn't. It appears to have something to do with the PCB being stamped with "NVIDIA" or "EVGA".
I just sent an email to EK asking them directly if the TitanX full block is compatible with my card. I'll post an update when I find out.
DixonCider is offline
