Polishing a reservoir? - Overclock.net
post #1 of 4 Old 10-09-2016, 12:35 AM - Thread Starter
333mhz
Alan1187's Avatar
Quoted: 0 Post(s)
Liked: 3
I've had my res for a few years now, and because of my case, it wasn't mounted as best as it should be, so there is some slight scuffing on the clear portion of it. This is an EK Res. What would be the best approach for getting these scuffs out and returning the luster the clear used to have there?
Alan1187 is offline
post #2 of 4 Old 10-09-2016, 11:09 AM
Jim86's Avatar
Quoted: 0 Post(s)
Liked: 2
Sand it with some really fine sand paper and purchase some polish and polish. Not sure why you didn't google how to polish acrylic.
Jim86 is offline
post #3 of 4 Old 10-09-2016, 02:58 PM
PC Gamer
DillonHightower's Avatar
Quoted: 0 Post(s)
Liked: 20
DO NOT USE SANd PAPER > you will not get the look you want and end up with more scufs than you want . . Just start with a really good polish and a polishing pad for your 4 in grinder or dremmel .
I have had really good luck with novus plastic polish kit . gives you everything you need in the kit and it is super cheap .
https://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU/ref=sr_1_1?ie=UTF8&qid=1476046618&sr=8-1&keywords=novus+plastic+polish+kit
Search you tube on how to use novus polish kit and there will be a few differnt videos of how to .
hope this helps . If you need any more help feel free to message me dude .
Alan1187 likes this.
Asus rampage 5 Edition 10
I7 6800k 4.2MHZ
32gb Corsair Vengeance
EVGA GTX 980 TI SC
Corsair ATX 1200
Corsair Force gt 500gb
Samsung SSd 500 gb
Case Labs STH10 AKA White Widow
Acer XB270HU
DillonHightower is offline
post #4 of 4 Old 10-09-2016, 06:48 PM - Thread Starter
333mhz
Alan1187's Avatar
Quoted: 0 Post(s)
Liked: 3
Awesome stuff. Thank you very much. I have a dremmel, but I can't recall what buffing pads I have for it right now, I'll look into it. But I'll add that stuff to my list and pick it up soon. Thank you.
Alan1187 is offline
