Aquacomputer mps 400 flow meter is dead? - Overclock.net
post #1 of 4 Old 12-16-2017, 02:33 AM - Thread Starter
zerophase's Avatar
Quoted: 0 Post(s)
Liked: 0
Well, my AQ flow meter has started reporting 0 gpm flow rate. The water definitely still flows fine. If I drop the pumps extremely low, and manually zero out the pumps, its possible to get a raw value of approximately 8.
It's probably going to take a few days for AQ to get back to me. In the mean time is there anything I can do to try to revive the meter? Maybe, cut the power to the pumps to try reseting the zero point? (auto zeroing during stand by doesn't seem to be happening)
zerophase is offline
post #2 of 4 Old 12-16-2017, 03:08 AM
Overclocker
jura11's Avatar
Quoted: 0 Post(s)
Liked: 97
Hi there
What coolant did you used?
Did you tried to remove MPS400 from PC and clean it, you can clean it,done it with my as well when I got strange or no readings from my MPS400
I'm now on second MPS400,first failed within few months and second one seems is working
With first one I run Mayhems Pastel Red and Aquacomputer don't recommend to use on their MPS Pastel fluid
On second one I'm using now Mayhems X1
Hope this helps
Thanks, Jura
jura11 is online now
post #3 of 4 Old 12-16-2017, 03:34 AM - Thread Starter
zerophase's Avatar
Quoted: 0 Post(s)
Liked: 0
I've been using pastel red with it for a couple years now. I did notice the flow dropped reading dropped slightly a few months back. Really, not sure when the flow started reading zero.
Guess I'm going to have to try cleaning the damn thing out. Just rub the mps down with paper towel and flush some distilled through it? Might have to wait a couple weeks, it's not exactly the ideal time for me to take the system down.
post #4 of 4 Old 12-16-2017, 03:45 AM
Overclocker
jura11's Avatar
Quoted: 0 Post(s)
Liked: 97
Hi there
Do you have enabled logging, if yes then check older logs
Regarding the cleaning,yes you can try with distilled water and regarding the rubbing not sure if you can do that as MPS400 is closed and opening MPS400 you can and clean the nozzle with syringe and distilled water
Hope this helps
Thanks, Jura
