Watercool my CoolerMaster Stacker 831 - Overclock.net
post #1 of 12 Old 02-24-2008, 05:25 PM - Thread Starter
733mhz
Epic's Avatar
Quoted: 0 Post(s)
Liked: 1
Currently running 3.6Ghz Q6600 @ 65c-70c under load, want either a good kit that wil fit into/on my CM Stacker that will be silent and give me really good cooling
Should i got for a pre-made kit or build my self?
Anyone got watercooling in there CM Stacker 831?
Epic is offline
post #2 of 12 Old 02-24-2008, 05:32 PM
4.0ghz
getllamasfast's Avatar
Quoted: 0 Post(s)
Liked: 100
You should build it yourself rather than buying a prebuilt kit.
TF2
getllamasfast is offline
post #3 of 12 Old 02-24-2008, 06:52 PM
733mhz
pwnage101's Avatar
Quoted: 0 Post(s)
Liked: 8
budget? and would you like internal or external?
edit: heres one that's good for the quad and isn't excessively expensive
D-tek FuZion
Swiftech MCR320
Swiftech MCP655
Radbox
8ft Tygon 7/16" ID 5/8" OD Tubing
1/2" T Line
Dangerden Fillport
12x Plastic Tubing Clamps
coolant:
opt1) Swiftech Hydrx (for a green loop)
opt2) Pentosin G11 + PT_Nuke
and make sure you use about 90% distilled water which you can purchase at the local grocery store.
max total: $251 before shipping
edit: oops forgot fans. just go ahead and add your choice of "Yate Loon" branded 120mm fans from jab-tech or petra's tech shop. since i put an MCR320 rad on the list, you'd best go with the SM or the SL version because as far as i know, higher cfm fans dont mean much for such a (air)flow-free rad.
pwnage101 is offline
post #4 of 12 Old 02-24-2008, 11:42 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 52
http://www.petrastechshop.com/pecoel.html
Best. Kit. Ever.
yeah brilliant...
Retarded babies, but at least you have a cool looking PC.
post-flame-small.gifWho We Fold Forpost-flame-small.gifFold For The Cause! Fold For The People.post-flame-small.gifE6400 @ 3.4GHz proof.gifpost-flame-small.gif
1 Million+ Folding at Home points
DaCrusader is offline
post #5 of 12 Old 02-24-2008, 11:50 PM
3.5ghz
Deezle98's Avatar
Quoted: 0 Post(s)
Liked: 60
Here's my setup in my stacker. GTX240 Rad, DD MC-TDX block, 3/8" tygon tubing and D5variable pump.
"Build a man a fire, he'll be warm for a night. Set a man on fire, he'll be warm for the rest of his life." biggrin.gif
This one time we started playing video games and my dad got mad and he started spanking my friend and took off his underware and he was crying.
Deezle98 is offline
post #6 of 12 Old 02-25-2008, 06:08 AM - Thread Starter
733mhz
Epic's Avatar
Quoted: 0 Post(s)
Liked: 1
What sort of temps will i be looking at? and should i think abouit watercooling the NB and Video Card as well to make it that extra silent and also better cooling all round?
Epic is offline
post #7 of 12 Old 02-25-2008, 07:43 AM
Commodore 64
x06jsp's Avatar
Quoted: 0 Post(s)
Liked: 0
epic i was just trying to reply to your pm and you dont have any free space so can you delete some pms so that i can reply to you cheers mate
x06jsp is offline
post #8 of 12 Old 02-25-2008, 08:23 AM - Thread Starter
733mhz
Epic's Avatar
Quoted: 0 Post(s)
Liked: 1
Space made
Epic is offline
post #9 of 12 Old 02-25-2008, 08:37 AM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
There getting you pretty well lined up on parts, it will be a lot harder to get high performance and a quiet rig, you'll need a lot more rad for the extra surface area and at least run some quiet fans on it...
Heres some stuff you might like to read...There is a lot of good reading in the stickies here also...
...Water Cooling - In English
...Assembling your Custom Watercooling Setup
...Bleeding my WC setup..
...D-Tek Fuzion install tip! (Or why you should clean new blocks)
...Poll: Push or pull configuration for Radiators
...Part 1- Temp's with and with-out shrouds
...PC Water Coolant Chemistry - Part I
...Cooling - An In-Depth Look
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #10 of 12 Old 02-25-2008, 08:44 AM
You're a Loose Cannon, Bobrovsky!
pow3rtr1p's Avatar
Quoted: 0 Post(s)
Liked: 570
Too bad it isn't heat holding back my CPU OC... I would like to go Watercooling, but this CPU pretty much won't run hot, no matter how high I OC it. I may make a loop just for my video card... >.>
pow3rtr1p is offline
