Just redid WC setup TEMP Check - Overclock.net
post #1 of 7 Old 03-07-2008, 12:27 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 6
i just redid my wc setup putting the rad on the bottom outside of my stacker 830.
But just to check my idle temps are 27c @1.5v @4.0GHZ
but as soon as i put full load it jumps up to 43c and levels out around 48-50c
is this normal or do i need to reseat the waterblock thanks
Rowland2004 is offline
post #2 of 7 Old 03-07-2008, 12:30 PM
1.7ghz
Robbie's Avatar
Quoted: 0 Post(s)
Liked: 22
You may need to re-seat your block a couple of time I did mine 5-6 time before I was happy with the temps.
ira-k likes this.
Robbie is offline
post #3 of 7 Old 03-07-2008, 12:32 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 6
did u take the thermal grease off and put it back on, and how do u apply yours ive been spreading out a thin layer?
post #4 of 7 Old 03-07-2008, 12:38 PM
1.7ghz
Robbie's Avatar
Quoted: 0 Post(s)
Liked: 22
Clean you cpu and block make sure there is no more on it. I use ACS5 I have tried many ways to apply it and the last way I did it was by applying a small amount in the middle of the cpu put the water block on it and twist it side to side the screw down the water block. Hope this help you.
Robbie is offline
post #5 of 7 Old 03-07-2008, 01:27 PM
Maximum Speed
dr4gon's Avatar
Quoted: 0 Post(s)
Liked: 676
wow, those are very good temps... What rad are you using and with what fans?
ambient temp?
post-flame-small.gifProject: Orange Box post-flame-small.gifUni-Sleeving your 24-pin PSU Guide post-flame-small.gif
camera.gifJoin the New OCN Flickr Group - My Flickr
Team Fortress 2 - Add OCN @ 68.232.173.130:27015
dr4gon is offline
post #6 of 7 Old 03-07-2008, 02:26 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 6
The rad is a Black Ice Extreme II X-Flow 240
just re-seated and temps are 25c idle and 45-47c load!!!!
Ambient temp is 71F Fans one Aero 78cfm broke the other so some 50cfm fan for now.
Heres some other pics of the mods today
Put some ruber around the rad and fans to seal it up a little.
post #7 of 7 Old 03-07-2008, 03:09 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 52
I love that blue with the lights, looks like a top OC rig
Rowland2004 likes this.
yeah brilliant...
Retarded babies, but at least you have a cool looking PC.
post-flame-small.gifWho We Fold Forpost-flame-small.gifFold For The Cause! Fold For The People.post-flame-small.gifE6400 @ 3.4GHz proof.gifpost-flame-small.gif
1 Million+ Folding at Home points
DaCrusader is offline
