Custom Watercooling Setup (Haven't purchased it yet) - Page 2 - Overclock.net
post #11 of 16 Old 03-10-2008, 06:49 PM
IT Nut
trueg50's Avatar
Quoted: 0 Post(s)
Liked: 676
Send a message via AIM to trueg50 Send a message via Yahoo to trueg50
Link to Sidewindercomputers.
They are a ton more, however you can pickup a better rad like the Black Ice Pro 3 for very cheap.
trueg50 is offline
post #12 of 16 Old 03-10-2008, 06:56 PM - Thread Starter
1.3ghz
Quoted: 0 Post(s)
Liked: 20
Send a message via AIM to tomclancey Send a message via MSN to tomclancey Send a message via Skype™ to tomclancey
Originally Posted by dr4gon View Post
Well the fuzion gfx is not a good choice for your loop because it will add way too much restriction.
How so? Since that may be the case, would you recommend any other GPU Block(s)?
I looked at the MCW60-R, it seems pretty good. I noticed in your 'Orange Box' thread, you used one of those, and got some D-Tek High-Flow Fittings, I think I'll go with that.
Originally Posted by ghost View Post
I would go thermochill for rad pricey but awsome.
Price isn't much of an opposition, but the cheaper the better.
http://www.sidewindercomputers.com/bliceproiiit.html
Is that it? Hm, I may get that instead, it's $3 cheaper then my MCR320 Quiet Power Radiator, but it's the same thing. 3x 120mm. (I don't know how much the quality would differ between the two, doesn't it just disperse the heat?)
tomclancey is offline
post #13 of 16 Old 03-10-2008, 08:08 PM
IT Nut
trueg50's Avatar
Quoted: 0 Post(s)
Liked: 676
That is what I have.
The spacing between the fins for the Swiftech is greater than that of the BIP III, so it works better with quiet (and thus low CFM) fans, so the BIP III cools better. Also the BIP III is a little shorter.
trueg50 is offline
post #14 of 16 Old 03-10-2008, 08:49 PM - Thread Starter
1.3ghz
Quoted: 0 Post(s)
Liked: 20
Okay, I'll get the BIP III, and not the swiftech. Though, I don't think size will be much of a problem. Least, I hope not in the Antec 900, I may eventually buy...
Any thoughts on the GPU Cooler?
post #15 of 16 Old 03-10-2008, 10:15 PM
1.3ghz
biftek's Avatar
Quoted: 0 Post(s)
Liked: 16
I'd go for the BI GTS personally.
Better than the BIP III in all cases, and even beats the PA's with high CMF (read: loud ) fans.
biftek is offline
post #16 of 16 Old 03-11-2008, 01:56 PM - Thread Starter
1.3ghz
Quoted: 0 Post(s)
Liked: 20
I'll still with the Black Ice GT Stealth 360 for now. I guess I'm all set with my water cooling, thanks so much for help guys! It was greatly appreciated.
