MC14 VGA ramsinks or HR-03 ramsinks? - Overclock.net
post #1 of 2 Old 03-24-2008, 10:05 AM - Thread Starter
1.3ghz
bfgDennis's Avatar
Quoted: 0 Post(s)
Liked: 10
Currently I have a HR-03 GPU cooler with thermalright ramsinks already attached to the card, but I will be using a MCW60 and I also will get a MC14 ramsinks
the question is should I stay with the thermalright ramsinks or use the MC14 ones
thanks
bfgDennis is offline
post #2 of 2 Old 03-24-2008, 10:34 AM
4.0 GHz
Pyr0's Avatar
Quoted: 0 Post(s)
Liked: 7
i switched from the standard hr-03 heatsinks to a d-tek unisink
needed a little bit of modding to get it to fit properly, but the card is much cooler and there's no risk of not cleaning the chips enough and the little heatsinks not sticking properly
Pyr0 is offline
