Newbie Watercooling No Much Money ;D - Overclock.net
post #1 of 13 Old 04-08-2008, 03:02 PM - Thread Starter
1.7ghz
matthiggins7's Avatar
Quoted: 0 Post(s)
Liked: 30
Hey guys part 2
ive found some bits, an im thinking about buying bit by bit here are some bits
Whats the best barb sizes im thinking 1/2 does it change performance
CPU Block: D-Tek FuZion £37 1/2" Nickle Plated
Pump: dB-1 Compact 12v Ultra Quiet Compact Pump £26
Rad: XSPC RS360 Black £28
Hose: PrimoChill Anti-Kink Coils 1/2"- Black
Res: XSPC Bay Reservoir - Black £19
And hose clamps but which are all the same i think LOL
so guys are these bits any good or just naff
an will it work better then air cooling or is it just the same?
Thank
Thanks Higgins
matthiggins7 is offline
post #2 of 13 Old 04-08-2008, 03:11 PM
3.5ghz
Xx_xBLADEx_xX's Avatar
Quoted: 0 Post(s)
Liked: 63
I wouldn't get black hoses because you can't see if you have air bubbles, and makes it much more harder to bleed the loop.
Maybe get Clear tubing, and dye your coolant close to a black, or just make your own coolant, with dyies to make black
That was the gayest post i've read in my life. You mounted a kid's dad, put him in a rear naked choke hold, and it was pure action? He was tall and thick? Geez. Can't you just say you kicked his ass instead of rammed it?
Xx_xBLADEx_xX is offline
post #3 of 13 Old 04-08-2008, 03:25 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 30
the cable isnt actually black, its clear tubing but with anti-kink black coil going around it
hw about the other bits they seem any good?
post #4 of 13 Old 04-08-2008, 03:27 PM
Audiophile
ace8uk's Avatar
Quoted: 0 Post(s)
Liked: 186
they seem good but im no watercooling expert, most places in the UK seem to have sold out of the dtek fuzion though
He calls your bluff; he is the ace you never thought he played that much.
ace8uk is offline
post #5 of 13 Old 04-08-2008, 03:36 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 149
Seems like a decent setup for someone on a budget. 3 protips.
1. BE PATIENT!
2. Triple check ALL connections before you even think of putting liquid in it and leak test for atleast 4-5 hours.
3. Take lots of pics.
Spart is offline
post #6 of 13 Old 04-08-2008, 04:33 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
Thats not bad at all, that pump should be fine with a cpu only loop and a Fuzion block...I wouldn't use jets in it, that would make it to restrictive with that pump, you can still install a washer and bow it for better performance with s/775..D-Tek FuZion Washer Made Easy. ...You might want a back-plate, it seems to help make better WB mounts.Dtek FuZion Intel 775 Pro-Mount set..I'm sure you can find them there to....I'll leave you my cleaning and set-up PDF to...Read all the stickies here also, good stuff in them...
...D-Tek Fuzion install tip! (Or why you should clean new blocks)
...How To: Clean out a D-Tek Fuzion CPU Block
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #7 of 13 Old 04-09-2008, 01:36 AM
Over 9000.
ChielScape's Avatar
Quoted: 0 Post(s)
Liked: 680
go for it. XSPC makes good rads.
ChielScape is offline
post #8 of 13 Old 04-09-2008, 02:17 AM
4.0ghz
TheNix's Avatar
Quoted: 0 Post(s)
Liked: 110
If the usual places dont have the block, i've found stock here, but its a bit more expensive than the rest.
TheNix is offline
post #9 of 13 Old 04-09-2008, 04:12 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 30
oh man this is great news
i gotta wait at least 2 weeks for pay day tho
ive seen that the EK cpu block has a better performance against a stock D-Tek but how about if i get the accelerator nozzle kit would it make any difference
an you reccomend gettings pro mounting kit
ive seen the results of a D-tek fuzion running a Q6600 at 3.5 at 57c
anyone no what kinda speeds an temp to expect when overclocking my e6600 ?
post #10 of 13 Old 04-09-2008, 09:02 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 30
cus currently my CPU with stock cooler 57c with a 2.5ghz OC
LOL
is there any difference in performance if you use a different size tube ?
