Water cooling question - Overclock.net
post #1 of 12 Old 04-11-2008, 04:37 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 4
i am a newb at H2O
i have an old radiator from a car approx 12" X 12"
and the pipes are huge 1" across
i was wondering if it would be possible aand feasible to make a wc computer with it mounted on the side probably with a 220v pump
how to connect it to the loop though because the tubes are usually smaller right???
samuraiweasel is offline
post #2 of 12 Old 04-11-2008, 07:00 AM
Hi!
billbartuska's Avatar
Quoted: 0 Post(s)
Liked: 1249
If the tubes are copper/brass you can just solder on a reducer. If it's aluminum you'll have to use a plastic reducer, some plastic hose and clamps.
You could make a shroud to adapt the fan to the radiator. That will also help get better cooling.
Misinformation is available from a variety of other sources. Misinformation is just like real information but wrong.
...and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 12 Old 04-11-2008, 07:04 AM
ldk
Overclocker - Duh!
Quoted: 0 Post(s)
Liked: 368
you'll also have to have a monster pump to move the water thru your radiator. i'd suggest getting the biggest one you can find.
ldk is offline
post #4 of 12 Old 04-11-2008, 07:37 AM
Hi!
Quoted: 0 Post(s)
Liked: 1249
I think it's a foregone conclusion that he will be able to equal the air flow nor the water flow that an automotive rad need to operate efficiently. The internal tubes are too large and the fin spacing is likely too great also. But that doesn't mean it won't work, just that it's not the best choice for watercooling a PC.
post #5 of 12 Old 04-11-2008, 07:41 AM
4387 point(s) total
Quoted: 0 Post(s)
Liked: 4426
i am a newb at H2O
The radiator is probably aluminum so be careful of galvanic corrosion. That means you have to use aluminum blocks. Also, car radiators generally are the condensor or oil type. They have a thick tube that loops through the fins. This rad design is not great for PC cooling since those are better for low flow, huge heat differences, and high pressure (not apply to PC cooling)
IF you go to the Plumbing store, they should have 1" to 1/2" adapters. You'll need to brazen, sweat, or solder them on.
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
post #6 of 12 Old 04-11-2008, 07:45 AM
ldk
Overclocker - Duh!
Quoted: 0 Post(s)
Liked: 368
you bring up a good point. car engines run much hotter than cpus and relatively speaking the cooling mechanism doesnt have to be as efficient.
ldk is offline
post #7 of 12 Old 04-11-2008, 07:48 AM
Back on the Air
losttsol's Avatar
Quoted: 0 Post(s)
Liked: 607
Make sure you clean that radiator thoroughly before using it with a computer. Old car radiators usually have a lot of crud in them.
losttsol is offline
post #8 of 12 Old 04-11-2008, 08:54 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 4
sorry forgot to upload the pic
here it is
it looks like a radiator with a tank on top and on the bottom...*with all the pipes coming from those two tanks...*
i guess ill be buying like 4 120mm fans soon...
*which cpu blocks are aluminium*
*whats the best shape for a cpu block cause i might just make one*
*the pump i use will be a 220V... but where should it be ? after rad before cpu right?*
*the blocks i see on newegg are half cu half al cu for base and al for top??? i thought it wasnt good to mix the two??*
edit*
post #9 of 12 Old 04-11-2008, 10:55 AM
Over 9000.
ChielScape's Avatar
Quoted: 0 Post(s)
Liked: 680
go pump->rad->CPU->res->pump again.
ChielScape is offline
post #10 of 12 Old 04-11-2008, 10:55 AM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
I'd just try to find a heater-core to use....If you use used cores or rads you risk plugging everything up with scale and crud thats built up inside of them..I'd only use a new one for that reason...
Maybe this will help..
...Barbs for heater-core-fstfrddy
...How to make a dual heater core fan shroud...
...WATERBLOCK DESIGN (With detailed technical drawings)
...Galvanic corrosion
...Find The Perfect Heatercore
samuraiweasel likes this.
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
