Going for Overkill, Need Advice - Overclock.net
post #1 of 11 Old 04-13-2008, 07:22 PM - Thread Starter
Syr, miss you!
h00chi3's Avatar
Quoted: 0 Post(s)
Liked: 342
I am going to run 2 MRC220's (in pull with deltas) in a single loop with my quad. So what would be the proper sequence in the series for this. I was thinking the following:
pump->rad->cpu->rad->res->
I know this is complete overkill but I want to do because I can.
Any help is appreciated and thanks in advance!
On your mark!
Get set!
Terrible...
2 Million+ Folding at Home points
h00chi3 is offline
post #2 of 11 Old 04-13-2008, 07:42 PM
3.0ghz
TonyL222's Avatar
Quoted: 0 Post(s)
Liked: 58
It wont make any appreciable difference IMHO. Do it which ever way is simplest and most straight forward to route.
h00chi3 likes this.
TonyL222 is offline
post #3 of 11 Old 04-13-2008, 07:46 PM - Thread Starter
Syr, miss you!
h00chi3's Avatar
Quoted: 0 Post(s)
Liked: 342
The only reason I am doing this is because of a case mod I am working on, and will fit perfectly, I know it won't make that much of a difference but, I want to at least do it right.
On your mark!
Get set!
Terrible...
h00chi3 is offline
post #4 of 11 Old 04-13-2008, 07:47 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 256
As long as the cpu gets cold water from the rad immediately and the pump pulls directly after a res, it doesn't really matter. I would do both rads then to cpu.
h00chi3 likes this.
kill em all while drunk then use their blood to mod a comp then kill myself devil-smiley-019.gif
xdaseinx is offline
post #5 of 11 Old 04-13-2008, 07:51 PM
OCN Retiree
Adrienspawn's Avatar
Quoted: 0 Post(s)
Liked: 496
Lol this is EXACTLY what im doing but with 2 Black Ices.
Id think that you should have both Rads before the block. like this:
h00chi3 likes this.
Adrienspawn is offline
post #6 of 11 Old 04-13-2008, 07:53 PM - Thread Starter
Syr, miss you!
h00chi3's Avatar
Quoted: 0 Post(s)
Liked: 342
Most god aweful example and yet it works. I think this is going to be my new plan!
On your mark!
Get set!
Terrible...
h00chi3 is offline
post #7 of 11 Old 04-13-2008, 08:26 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
I'd stick them both before the chip to...Are you going to use the 3 blade Delta's? They have some really good pressure....If you ever get a chance to pick up a BIX or a Bonnie heater-core grab one, they love those high pressure fans..The Swifty are optimized for lower cfm fans, but more air and higher pressure still has to help some..
Let us know if it drops your temp's much, your already getting good temp's so it might not be a lot of gain, but any gain is good...
h00chi3 likes this.
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #8 of 11 Old 04-13-2008, 08:34 PM - Thread Starter
Syr, miss you!
h00chi3's Avatar
Quoted: 0 Post(s)
Liked: 342
Yeah I got my hands on the 3 blade deltas, I will try it with those and then go to my 120x25 yate loons I got from Petras and see if there is a difference. I just wanted to try something new out, that is all. Thanks again everyone!
On your mark!
Get set!
Terrible...
h00chi3 is offline
post #9 of 11 Old 04-14-2008, 08:54 AM
Over 9000.
ChielScape's Avatar
Quoted: 0 Post(s)
Liked: 680
if you're gonna buy a new case, get teh Lian li armorsuit PC-P80, it should mount the 480GTX rad internally.
also, overkill setup details here
ChielScape is offline
post #10 of 11 Old 04-14-2008, 10:21 AM
IT Nut
trueg50's Avatar
Quoted: 0 Post(s)
Liked: 676
FYI your pump pumps th opposite way, thus your flow is going in the wrong direction. All you have to do is flip the pump, however that pump placement isn't terribly good.
TonyL222 likes this.
trueg50 is offline
