WC ideas for my new V1000 - Page 2 - Overclock.net
post #11 of 18 Old 12-12-2008, 05:53 PM
Moldder
nafljhy's Avatar
Quoted: 0 Post(s)
Liked: 631
wait.. the rad is internal... but wouldn't it be blocking the mobo oc'ing?
8 Million+ Folding at Home points
nafljhy is offline
post #12 of 18 Old 12-12-2008, 06:01 PM - Thread Starter
OC'ing Noob's Avatar
Quoted: 1 Post(s)
Liked: 848
nope not unless i try to stick the sound card at the very bottom pci slot
Overclock.net Mod of the Month 0109  Overclock.net 10 Year Member
OC'ing Noob is online now
post #13 of 18 Old 12-12-2008, 07:52 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
Originally Posted by OC'ing Noob View Post
Yea I am thinking of using either aluminum or white plexi.
Plexi would probably quiet down your fans more, I know you don't like noise...
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #14 of 18 Old 12-12-2008, 08:24 PM
733mhz
Quoted: 0 Post(s)
Liked: 1
wat ur not gonna paint the case or do some body work on that case?? Pimp that Rig is wat i have to say!
Originally Posted by nikhsub1
I suppose you use magic to affix your WB to the cpu? Perhaps you have little elves hold the damn things on for you? Or maybe, Ivanka Trump comes and begs you to let her apply 60 lbs of pressure to your WB? No, I bet that Heather Mills lends you her fake leg to wedge the WB into place
MikuMiku is offline
post #15 of 18 Old 12-13-2008, 01:40 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 848
LOL you know me too well ira-k. Yea either white plexi painted white with enamel based paint with laquer clear or aluminum with rubber inlays.
- Case will be powder coated pearl white
- Side panel will have a circle window and koi laser cut into it
- Will be airbrushed
- Tentative image of a princess in a kimono under a bamboo umbrella smiling over her shoulder on the window side with a sakura tree behind her scattering leaves around the case to form a moon on the other side with another princess in a kimono dipping her hand into a big koi pond.
Those however are for case modding and not water cooling
post #16 of 18 Old 12-13-2008, 03:07 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 848
Change of plans....I am going to use a 360GTX due to the fact that it is simply impossible to rig any sort shroud that will look decent due to space constraints.
post #17 of 18 Old 12-13-2008, 08:01 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 194
just wondering... for the rad, pull out or push in?
LiquidForce is offline
post #18 of 18 Old 12-17-2008, 03:30 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 848
pull hot air out of the case.
