i thought it was going to drop temps? - Overclock.net
post #1 of 7 Old 11-28-2005, 07:01 PM - Thread Starter
Commodore 64
handle's Avatar
Quoted: 0 Post(s)
Liked: 0
so i bought a thermaltake big water se to cool the system down but i dont think its working to well, i mean i idle around 105-109F and under load i am around 125F, any suggestions, i am using what came with the kit for liquid and i used as5...
handle is offline
post #2 of 7 Old 11-28-2005, 07:05 PM
Overclocker
accskyman's Avatar
Quoted: 0 Post(s)
Liked: 196
You might want to make sure theres no air in the system, and make sure the fan is moving a good bit of air over the radiator etc.
Otherwise let it on for a few days with something running that will periodically heat up the CPU, the block/AS5/processor takes a little while to "burn in" as some people call it. I know my temps drop about a week after I removed the HS and put it back on.
Chimp Challenge Participant  Overclock.net 10 Year Member
accskyman is offline
post #3 of 7 Old 11-28-2005, 07:29 PM
Resistance is Futile
Quoted: 0 Post(s)
Liked: 387
Actually... Alot of people have stated the the Thermaltake Big Water system is not that good. I have not used one myself so I can only pass on what I have heard. However you might check for air in the system. If no air in system then let the AS5 cure, it will take 200 hours to do that, and see what the temps are then.
Great spirits have always encountered violent opposition from mediocre minds.
If you ask a question you don't want an answer to, Expect an answer you don't want to hear.
lonnie5000 is offline
post #4 of 7 Old 11-29-2005, 07:20 AM
333mhz
Quoted: 0 Post(s)
Liked: 1
i have the bigwater on a 4000+ idle 33 load 41 in a thermaltake armour case
reefmaster22 is offline
post #5 of 7 Old 11-29-2005, 12:29 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 149
if you just installed if, you'll probably have to wait for air to bleed out of the system a little bit, and wait for AS5 to break in before you get max. performance out of it
though thoes temps are pretty typical for a bigwater on a s478 prescott... the bigwater just isn't a good kit... i mean, yes, its water cooling, but a very crappy kit at it :-/
CrimsonMango is offline
post #6 of 7 Old 11-29-2005, 12:32 PM
Blue_Fire's Avatar
Quoted: 0 Post(s)
Liked: 115
agreed, let the as5 cure, and purge the system. it is sealed for the best performance. try coolants aswell.maybe a chiller.
"Overclock.net headphones club: Because perfect hair is overrated."
Blue_Fire is offline
post #7 of 7 Old 11-29-2005, 05:17 PM - Thread Starter
Commodore 64
handle's Avatar
Quoted: 0 Post(s)
Liked: 0
thx for the reply guys. i guess i will just sit it out a week or so and bleed it out and let the as5 cure, the temps seem 4 degrees cooler today. could of been that my room temp was like 80 degress also. dont know if it makes a differnce but my case temp is sitting at 80-82F.
handle is offline
