OCN Water Cooling Club And Picture Gallery - Page 3280 - Overclock.net
post #32791 of 107797 Old 11-25-2012, 11:16 AM
PC Gamer
Quoted: 0 Post(s)
Liked: 21
Just finished adding an ex 120 into the loop let me know what you guys think. thumb.gif
40.oz to freedom is offline
post #32792 of 107797 Old 11-25-2012, 11:59 AM
Hardline upgrade!
Ceadderman's Avatar
Quoted: 0 Post(s)
Liked: 695
Originally Posted by KaRLiToS View Post
Originally Posted by B NEGATIVE View Post
Take one plain looking EK dual top..
Add copper
This piece needs to be hit with a bench buffer before it goes on,i have seen one at a good price so that will be my next purchase for the 'lab'
There will be a matching piece for the pump side too,should look good when its done.
How will you install it on the Pump Block? Glue?
(I really love the look of it, but nickel drool.gif )
10 Million+ Folding at Home points  Chimp Challenge 3 x Participant  Foldathon Folder - 2013 Participant  Foldathon Participant 2015  Foldathon Participant 2016
Ceadderman is online now
post #32793 of 107797 Old 11-25-2012, 12:47 PM
Senpai Studios
derickwm's Avatar
Quoted: 0 Post(s)
Liked: 392
Originally Posted by Sixtron View Post
Yes in construction and production.
Be sure to check out my build log, you guys sponsored me some blocks for it biggrin.gif
Chimp Challenge Participant  30 Million+ Folding at Home points
derickwm is offline
post #32794 of 107797 Old 11-25-2012, 12:53 PM - Thread Starter
Hardware Rep
B NEGATIVE's Avatar
Quoted: 0 Post(s)
Liked: 778
Originally Posted by Ceadderman View Post
Thanks man,2mm Copper sound easy to file and shape but it so isnt.....
Should look good with the matching backplate on the pump side
B NEGATIVE is online now
post #32795 of 107797 Old 11-25-2012, 02:23 PM
Quoted: 0 Post(s)
Liked: 14
How did you manage to mount it (bottom rad)? Looking good. Cheers.
PTCB is offline
post #32796 of 107797 Old 11-25-2012, 03:02 PM
Norelec's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by jokrik View Post
How long has it been going on?
took me 3-4 days to add more coolant in my loop. Nothing has been added ever since
sorry i didn't reply to you in my other reply i missed your post. Loop has been running for around 2mths total and was rebuilt about 1mth ago for a leak check. havn't added anything since my last post a few days ago it hasn't dropped any so looking good for now.
Norelec is offline
post #32797 of 107797 Old 11-25-2012, 03:23 PM
WaterCooler
xlink64's Avatar
Quoted: 0 Post(s)
Liked: 4
Not sure how he did his, but I just used scotch mounting tape for mine =P
xlink64 is offline
post #32798 of 107797 Old 11-25-2012, 04:25 PM
Quoted: 0 Post(s)
Liked: 14
Nice. So basically you cut out the bottom and stick the rad to the chassis using the tape? Thanks.
PTCB is offline
post #32799 of 107797 Old 11-25-2012, 04:27 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 21
I dont have it mounted its a snug fit between the case and the brackets for the hdd cage that i removed so its just sitting on 2 pieces of foam until i can get a new dremel and cut out and hole for it to screw into the case.
post #32800 of 107797 Old 11-25-2012, 04:50 PM
Overclocker
Nyghtryder_9's Avatar
Quoted: 0 Post(s)
Liked: 36
Very nice. How long do you think until will be able to purchase? I can always test your prototype out if you need... you know to make sure it will keep the temps nice and cool biggrin.gifthumb.gif
2 Million+ Folding at Home points
Nyghtryder_9 is offline
