OCN Water Cooling Club And Picture Gallery - Page 6744 - Overclock.net
post #67431 of 107797 Old 05-08-2014, 01:31 PM
nVidia Enthusiast
Quoted: 0 Post(s)
Liked: 23
Originally Posted by Gabrielzm View Post
You can also use Blue Dye. I tested it in a Small Glas with Red Paset (about 100ml of Pastel) and with 1 Drop from the Blue Dye it was nearly Black ! tongue.gif
psycho84 is offline
post #67432 of 107797 Old 05-08-2014, 01:42 PM
Waterbug
Gabrielzm's Avatar
Quoted: 0 Post(s)
Liked: 399
Gabrielzm is offline
post #67433 of 107797 Old 05-08-2014, 03:03 PM
Dirt Farmer
skupples's Avatar
Quoted: 0 Post(s)
Liked: 505
skupples is offline
post #67434 of 107797 Old 05-08-2014, 03:09 PM
Kinaesthetic's Avatar
Quoted: 2 Post(s)
Liked: 462
Originally Posted by skupples View Post
made some changes.
Looks so much better without that white tubing.
I hate fanboys/fangirls. You ruin the friendlyshilling atmosphere of OCN./s
Kinaesthetic is offline
post #67435 of 107797 Old 05-08-2014, 03:10 PM
Dirt Farmer
skupples's Avatar
Quoted: 0 Post(s)
Liked: 505
skupples is offline
post #67436 of 107797 Old 05-08-2014, 03:26 PM
BradleyW's Avatar
Quoted: 0 Post(s)
Liked: 1554
BradleyW is offline
post #67437 of 107797 Old 05-08-2014, 03:38 PM
Overclocker
Arm3nian's Avatar
Quoted: 0 Post(s)
Liked: 37
Is there anyway to troubleshoot a d5 pump? Mine is making gurgling noises, especially at the faster speed settings. I took it apart and there doesn't seem much I can do.
Here is my model: http://www.ekwb.com/shop/pumps-and-accessories/pumps/ek-d5-series-pump/ek-d5-vario-x-top-acetal-incl-pump.html
Arm3nian is offline
post #67438 of 107797 Old 05-08-2014, 03:43 PM
Dirt Farmer
skupples's Avatar
Quoted: 0 Post(s)
Liked: 505
cavitation, top on too tight, 90s on the out... ?
skupples is offline
post #67439 of 107797 Old 05-08-2014, 03:44 PM
BradleyW's Avatar
Quoted: 0 Post(s)
Liked: 1554
I've got the exact same pump and the exact same issue. Which port are you using for the outlet? Speed setting 5 makes a giggling noise. However, 4 and below are silent.
BradleyW is offline
post #67440 of 107797 Old 05-08-2014, 03:46 PM
Waterbug
Gabrielzm's Avatar
Quoted: 0 Post(s)
Liked: 399
The same tip I give to BradleyW applies here. Are you sure the screws in the ek top are not to over tight? We all tend to screw those things all the way and exerting too much pressure with the idea of sealing really tight the top and avoid leaks (In fact the sealing is made by the o-ring and no need to exert too much pressure). However, in doing so the top can push down on the impeller creating a gurgling sound, specially at high speeds, with the side consequence of also hindering flow. So test outside your system and try to loose a little bit the screws to see if that solves your problem. It worked to me and I learned in the hard way. The tip was given to me by people at FrozenCPU (Geoff).
BradleyW likes this.
