OCN Water Cooling Club And Picture Gallery - Page 8220 - Overclock.net
post #82191 of 107797 Old 04-01-2015, 03:49 PM
Fan Man
ozzy1925's Avatar
Quoted: 0 Post(s)
Liked: 35
guys today i installed my ek strix 980 blocks .I did the first one is perfect but after installing the second one i see there are some cracks near these screws.I didnt touch any ot these.Any idea how could this happen?
ozzy1925 is offline
post #82192 of 107797 Old 04-01-2015, 04:02 PM
Case Modder
KRONQS's Avatar
Quoted: 0 Post(s)
Liked: 2
Wolfsbora likes this.
Evolution-Tech
KRONQS is offline
post #82193 of 107797 Old 04-01-2015, 04:10 PM
We Are Mad!
wermad's Avatar
Quoted: 0 Post(s)
Liked: 906
Originally Posted by tipes View Post
Turned out to be the radiator that was at fault - despite passing the blow test. It has been a really aggravating day trying to sort this out.
Think I have finally got it sorted so now back to flexible hose and my trusty UT60 - oh well !!!! Now for some testing to see if it is really ok.
Many thanks to all those that helped on these issues - saved my sanity.
Mark
Ps my Titan X block and backplate turned up today - so fitted those as well. Titan now idles at 27 degrees.
Woot, Woot wheee.gif. That's the first thing that came to mind when you mentioned you switched.
Sorry I couldnt get you pump rpm for your pump concerns. My mb is in horizontal and with all the components, it's a pain to get to the cpu header.
wermad is offline
post #82194 of 107797 Old 04-01-2015, 05:16 PM
Jeffinslaw's Avatar
Quoted: 0 Post(s)
Liked: 184
Warning: Spoiler! (Click to show)
It looks like the factory over tightened the screws causing hairline fractures in the plexi. It won't leak, but I think that is eligible for RMA.
My EK Supreme HF CPU block has those hairline fractures where the fittings screw in from me over tightening the fittings.
-Jeffinslaw
Jeffinslaw is offline
post #82195 of 107797 Old 04-01-2015, 05:29 PM
Fan Man
ozzy1925's Avatar
Quoted: 0 Post(s)
Liked: 35
-Jeffinslaw
May be but they were ok before installing.Could be because the gpu block surface was not flat and it did stress the plexi after installation?
ozzy1925 is offline
post #82196 of 107797 Old 04-01-2015, 05:39 PM
Jeffinslaw's Avatar
Quoted: 0 Post(s)
Liked: 184
-Jeffinslaw
Are you sure they weren't there before the install? You said you noticed them afterwards, maybe you missed them before the install?
post #82197 of 107797 Old 04-01-2015, 06:01 PM
WaterCooler
guitarhero23's Avatar
Quoted: 0 Post(s)
Liked: 57
Originally Posted by hamed599 View Post
Thank you my friends
yes this is first my build
just trying to understand what is this box near the RAM and the 24pin connector to the MB ? this is Aquacomputer Flow Sensor
also what case is this ? case is enermax fulmo gt
What coolant are you using, I used the XSPC ECX Ultra Concentrate Coolant - UV Blue
Changes in my case
How did you cut the acrylic midplate lines?
guitarhero23 is offline
post #82198 of 107797 Old 04-01-2015, 06:07 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 57
Ok guys here are the tests I promised. (Took longer than I thought because I decided to make them into .gifs but I said I would do it!
@Alex132
@TheCautiousOne
@Yungbenny911
Blue On Black
White On Black
Blue On White
Let me know if the gifs aren't working for you, I can just post pics.
As you can clearly see in the last .gif the blue looks MUCH better after the item was painted white first.
Alex132, Ceadderman and Rahldrac like this.
post #82199 of 107797 Old 04-01-2015, 06:08 PM
Fan Man
ozzy1925's Avatar
Quoted: 0 Post(s)
Liked: 35
yea positive there wasnt any crack, i just see with the water block installed the pcb is now bent what am i going to do?
ozzy1925 is offline
post #82200 of 107797 Old 04-01-2015, 06:22 PM
timerwin63's Avatar
Quoted: 0 Post(s)
Liked: 70
yea positive there wasnt any crack, i just see with the water block installed the pcb is now bent what am i going to do? Warning: Spoiler! (Click to show)
To my untrained eye, I'd say take off the backplate first and see if the PCB is still bent. It could be a problem with that.
"Roses are red, violets are blue. They don't think it be like it is, but it do."
"What I've done so far is pour alcohol on things - it helps people, so I figured it would be the same for keyboards."
Clubs (Click to show)
Heatware: http://www.heatware.com/eval.php?id=101432
timerwin63 is offline
