Watercooling Setup For 250-275? - Page 2 - Overclock.net
post #11 of 23 Old 12-27-2005, 04:44 PM
Blocksmith
fstfrddy's Avatar
Quoted: 0 Post(s)
Liked: 408
You can forget the steel clams if you want and save some there, zip ties will keep it as watertight as a frogs butt.
fstfrddy is offline
post #12 of 23 Old 12-27-2005, 04:46 PM
ČøñЯδe
zerohour's Avatar
Quoted: 0 Post(s)
Liked: 140
Yikes Chopes! I didn't know you weren't on a budget! You may as well go single stage phase! I think you could save a good $100 if you shopped around for a different GPU block and pump too...
zerohour is offline
post #13 of 23 Old 12-27-2005, 04:48 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 316
I looked around that shop that you gave me and that was the only one that I could find for the gpu block. Any suggestions on that?
Secondly, I was wondering about the pump, I dont want to be lacking on the pump power, anything cheaper that can get me the same "punch?"
Chopes is offline
post #14 of 23 Old 12-27-2005, 05:04 PM
ČøñЯδe
zerohour's Avatar
Quoted: 0 Post(s)
Liked: 140
Sure thing, look here: http://www.cooltechnica.com/Merchant...egory_Code=VCW . Any of those will work because you can order universal mounting hardware. If you get one of those you will have to pick up some RAMsinks to cool the memory but those are only $10 or so. Thise will be a much cheaper way to cool your GPU.
*EDIT* i would also look at this pump: http://www.crazypc.com/Merchant2/mer...duct_Code=9336
zerohour is offline
post #15 of 23 Old 12-27-2005, 05:19 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 316
Ok I changed the pump, more questions now.
Do I need a molex converter because the molex's in my case are 4 pin, and that looks like it will be a 3 pin?
Secondly, do you have any recomendations for a gpu that doesnt need me to "mess with" the fittings. I dont really want to do that.
Lastly, where can I find the greese I need for the sub temps?
More lastly, do I need a radiator for my setup since I am using a pelter on my cpu and not the gpu?
Chopes is offline
post #16 of 23 Old 12-27-2005, 06:43 PM
ČøñЯδe
zerohour's Avatar
Quoted: 0 Post(s)
Liked: 140
Ok here we go:
-You will not need any adapter for the pump, it is DC voltage which means it has a 4 pin molex connector so you plug it into your PSU and it will turn on when your computer does.
-With the GPU blocks I showed you all you need to do is select the fittings on the page after you click on them. The fittings are just the back plates that the GPU block are mounted to, that is it, no "messing" required.
- grease can be found here: http://www.crazypc.com/Merchant2/mer...duct_Code=9345
- you may also want this: http://www.crazypc.com/Merchant2/mer...uct_Code=93460
and this: http://www.crazypc.com/Merchant2/mer...duct_Code=5931
-Yes you will need a radiator because the TEC gets very hot and you still need to cool the water going to it. I highly suggest that Swiftech block because its a waterblock with a TEC in it so the waterblock cools the hot side of the TEC while the cool side of the TEC cools the CPU. A dual heatercore would be sufficient for a CPU but I am not sure about a CPU and a GPU. You may need something bigger than a heatercore, or two heartercores like this: Res>Pump>HC1>CPU>HC2>GPU>Res>Pump etc.
I think that would be good, but I am no expert so 2 heatercores may be overboard, if a more knowledgable person can elaborate that would be great.
Good luck
zerohour is offline
post #17 of 23 Old 12-28-2005, 01:27 AM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
If you are a first timer with water cooling I would say just try that out first. You can always add the pelter later. I am sure you will be more then happy with your temps with just water. I am running a AMD 64 3200+ (2Ghz stock) at 2.5Ghz and a GeForce 6800GS (425Mhz core/1Ghz mem stock) at 500Mhz/1.5Ghz with temps of 23-25 idle 33-35 full load. That's a 25% OC with tons of room for more.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #18 of 23 Old 12-28-2005, 06:39 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 316
Ok I think ill take your advice snerp after talking with acouple people. I have a semi budget setup right here. Do you guys think this is an above average setup?
TOTAL: 331.71, around 350-360 after shipping.
Chopes is offline
post #19 of 23 Old 12-28-2005, 06:48 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 316
Sorry for double post, but I will need fans for my rad correct? If so how many, are there already bracketed places for them or how does that work?
http://www.newegg.com/Product/Produc...82E16835180019
what do you think of using those fans?
Chopes is offline
post #20 of 23 Old 12-28-2005, 07:04 PM
333mhz
Wipps Almighty's Avatar
Quoted: 0 Post(s)
Liked: 2
Hey could someone put togethor a list for watercooling for me? Kinda new to the idea but doesn't seem that difficult. So if you could put a list togethor for me for under say $450 lol not much of a limit i know so basically the skighs the limit. Goinna need this stuff for my new rig pretty soon
Wipps Almighty is offline
