(Guide) H50 Replace Tubes and Res Mod. - Page 7 - Overclock.net
post #61 of 418 Old 02-14-2010, 09:41 AM
3.5ghz
Leon777's Avatar
Quoted: 0 Post(s)
Liked: 44
Originally Posted by smashed_99cbr View Post
interesting... a few have said that this kills the pump before to long is that true? or is this just the guys that do it with out a res or t line?
I know it does not kill the pump, as will is still going strong.
there isnt a t line on this so i wouldnt know, a im not to sure it would make a diffrence without a res.
2 Million+ Folding at Home points
Leon777 is offline
post #62 of 418 Old 02-14-2010, 09:44 AM
3.5ghz
Leon777's Avatar
Quoted: 0 Post(s)
Liked: 44
Originally Posted by =wc=old_school View Post
this might sound like a dumb question but, which way is the h50 facing for the 2 screws to take off the cover? cant tell? it looks like you can turn it either way and the screws match up the same? i also noticed the way you showed in the diagram on how to run the tubing, that you did it a different way. the reason i ask these questions is because i bought all the things required to do this mod and i dont want to screw it up
I dont know about the first part of the qesution but will said RAD>>h50/pump unit>>RES>>RAD and he did it the same way he showed in the diagram... ?_?
Leon777 is offline
post #63 of 418 Old 02-15-2010, 12:44 AM
4.0ghz
arbalest's Avatar
Quoted: 0 Post(s)
Liked: 167
Not true... No worries. If I ever get free, I'll give you a call and you can see my setup
I <3 You!
arbalest is offline
post #64 of 418 Old 02-15-2010, 02:28 AM
333mhz
Scart's Avatar
Quoted: 0 Post(s)
Liked: 0
Scart is offline
post #65 of 418 Old 02-15-2010, 11:10 AM - Thread Starter
EXTREME EVERYTHING
Willhemmens's Avatar
Quoted: 0 Post(s)
Liked: 217
Willhemmens is offline
post #66 of 418 Old 02-17-2010, 10:54 AM
Balb0wa's Avatar
Quoted: 0 Post(s)
Liked: 5
in the process of doing mine, my tubing fits the pump and radiator perfect, but the Swiftech MCRes Micro V2 has bigger barb things on, what size do i need?
Pretty sure my tubing is 6mm internal diameter.
Hope you can help, thanks
do i need something like this??
http://specialtech.co.uk/spshop/cust...at=1254&page=1
Gigabyte GA-Z77X-UD5H
Intel CPU Core i7 3770K Ivy Bridge @ 4.8Ghz
2x Gigabyte GTX 670 Windforce 3X 2GB GDDR5 (SLI)
16 GB (4X4) Corsair DDR3 Vengeance Arctic White,1600mhz,CAS 9-9-9-24, 1.35V
Asus Xonar DX 7.1 - Thermalright Silver Arrow
Roccat Kave 5.1 Surround Sound Analog Gaming Headset
LiteOn 20X SATA DVD±RW/RAM
DGM 2701WPH 27 LED 2560x1440 WQHD S-IPS
Crucial RealSSD M4 128GB 500MB/S
1 x Samsung F3 1TB -2x Samsung F4 2TB
Fractal Design R3 - Corsair 850W Modular PSU
Windows 8 64 Bit
Balb0wa is offline
post #67 of 418 Old 02-17-2010, 12:04 PM
Case Modder
tlxxxsracer's Avatar
Quoted: 0 Post(s)
Liked: 59
You need G 1/4" barbs that are made for tubing with ID of 1/4"
I used these on my micro res http://www.performance-pcs.com/catal...ducts_id=22956
My H50 mod tutorial
My Lian-Li A70F mod worklog "Blaue Liebe"
Check out and subscribe to my youtube channel
https://www.youtube.com/chrispantonstechworld
tlxxxsracer is offline
post #68 of 418 Old 02-17-2010, 12:37 PM - Thread Starter
EXTREME EVERYTHING
Quoted: 0 Post(s)
Liked: 217
They would do just fine, if they were in stock.
Chimp Challenge 2 x Participant  Chimp Challenge Participant  4 Million+ Folding at Home points
post #69 of 418 Old 02-17-2010, 12:40 PM
Balb0wa's Avatar
Quoted: 0 Post(s)
Liked: 5
yes shame, il find some somewhere, just as long as i know there ok
Windows 8 64 Bit
Balb0wa is offline
post #70 of 418 Old 02-26-2010, 08:09 AM
3.5ghz
Leon777's Avatar
Quoted: 0 Post(s)
Liked: 44
Find any in the end?
+ Bump for the great guide
Leon777 is offline
