1/2 tubing over 3/8 - Page 2 - Overclock.net
post #11 of 33 Old 01-24-2006, 07:50 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 85
Originally Posted by Burn
Using 1/2 Primoflex, I was able to route it out the back PCI slots, it didn't scratch or rip or tear at all and still get 1/2" flow. I'd suggest you do that; moving to 3/8" is difficult, try to find a pump.
u wouldnt happen to have a pic?
EDIT: found the tubing on frozencpu
timsvpr is offline
post #12 of 33 Old 01-24-2006, 07:51 PM
Original OCN Gangsta
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Unfortunately, no. Tomorrow around 5 EST I may though.
timsvpr likes this.
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
1 Million+ Folding at Home points
Burn is offline
post #13 of 33 Old 01-24-2006, 07:57 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 85
Originally Posted by HatedEnemY
you want to stay away from the modding? i think that modding does give it the look of *Bling**Bling* but how do you plan to get a 3/8 tube out of the case? where are you making it exit? that can help some
im using pci cover slots that have holes for 3/8 tubing to go through.
timsvpr is offline
post #14 of 33 Old 01-24-2006, 07:58 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 85
thats cool - whenever. I dont get my taxes back until about two weeks
timsvpr is offline
post #15 of 33 Old 01-24-2006, 08:09 PM
4.0ghz
shortfuse's Avatar
Quoted: 0 Post(s)
Liked: 116
looking at ur case there shouldnt be a problem with using a 1/2 tube., ur case has plenty of room to go around specially now ur eliminating a big chunk of HEATSINK. are u using raid or single HDD? cuz if its a single hard drive u can buy those adapters for the HDD to fit the 5.25 bay, u have 4 slots on the 5.25 bay i doubt u will be using all 4. and seeing how everything is inverted in the inside (mother board) u will have enough space / clearance to place the pump or a cylinder reservoir.
timsvpr likes this.
OPTEROwNErs club
Originally Posted by muffin
shortfuse is offline
post #16 of 33 Old 01-24-2006, 09:23 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 85
thats what i was going to do in the first place. With a 120 sized rad in the front. I had it all planned out with 1/2 tubing then someone suggested to get a larger radiator outside the case for optimum temps.
So whats better a 120 sized rad with 1/2 tubing
or
A 240 or bigger rad with 3/8 tubing??
timsvpr is offline
post #17 of 33 Old 01-24-2006, 09:50 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
You can make the 1/2" tubing work with the 2x120 rad outside your case. Take the holes from 3/8" to 5/8" (5/8 will probably be the outter demention of your 1/2) and add 5/8ID grommets. If 5/8 is the exact size of the PCI slot still drill the holes and then epoxy the grommets to the PCI bracket.
timsvpr likes this.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #18 of 33 Old 01-24-2006, 10:28 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 85
this is what i planned on using. I measured a pci slot cover and its 3/4" wide. If i get the tygon 1/2" tubing that has an outside diameter of 3/4" i might be ok.
timsvpr is offline
post #19 of 33 Old 01-24-2006, 10:50 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
I personally would just make my own like I said. Save yourself $10 or however much it cost. Make sure you get grommets so the tubing dosen't end up getting cut.
Snerp is offline
post #20 of 33 Old 01-24-2006, 11:00 PM
4.0ghz
metalkobra's Avatar
Quoted: 0 Post(s)
Liked: 234
I have mine through the PCI slots here lemme show ya...I had to mod them a bit for the slot i wouldnt use though, its best to go through the very bottom slot that you wont ever use...
timsvpr likes this.
metalkobra is offline
