2 fans or 4 fans on the heatercore/radiator? - Overclock.net
post #1 of 4 Old 02-04-2006, 06:48 PM - Thread Starter
Overclocker in Training
Quoted: 0 Post(s)
Liked: 324
As the title says which would be best bang for the $ 2 fans or 4 fans since i am planning to upgrade my air cooling on the heatercore to get my load temps down a bit. Currently using 2 of these http://www.tigerdirect.com/applicati...6&Sku=ULT31814
Build log of Rocktfish case mod now finished Water fish
systemaxd is offline
post #2 of 4 Old 02-04-2006, 07:24 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
Send a message via AIM to Snerp
I use two on my heatercore, but I'm sure 4 will help a bit.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
post #3 of 4 Old 02-04-2006, 07:27 PM
Original OCN Gangsta
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
What I have found is that it makes no difference in airflow- you're going to push or pull the same amount of air through the core regardless of how many you have pulling or pushing. Currently, I have 2 Antec Tri-speed fans blowing on lowest setting, 2 @ 30CFM each, and I notice no difference in load temps at full blast versus the lowest setting. I think you only need 2 fans, but that's just me.
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
Burn is offline
post #4 of 4 Old 02-04-2006, 08:55 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
I notice a 2-3C difference when I have my 2 fans on full blast and turned all of the way down. I think the reason for having the 4 fans is to get more of an even airflow? I dunoo. The only reason I didn't put 4 fans on mine is I am a cheap bastard.
Snerp is offline
