Help me plan my WC setup placement please... - Overclock.net
post #1 of 7 Old 02-19-2006, 01:22 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 223
Here's what I'm getting/got:
'77 bonneville heatercore
DD TDX
DD Mave4 gpu
DD D5 pump
10' 1/2" Tygon tubing
DD fillport
T-line fitting
It's all going in/on a CM Stacker 810. I think the best place for the rad is on top of the case. I need help in placement of the pump, fillport, and T-line. Theres an attatched pic of what I'm thinking so far.
Piracy is not theft, stop the future before it happens! May Server protect us all!
Please listen to Tales From the Afternow!
Disclaimer: Listening to the above referenced audio may violate the terms of your listeners license and may result in termination. Remember, unregulated speech is pornography, sharing is theft.
1 Million+ Folding at Home points
Urufu_Shinjiro is offline
post #2 of 7 Old 02-19-2006, 01:28 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 116
i think u might need to read the following mate
http://www.overclock.net/faqs/70838-...how-can-i.html
it will give u a complete picture of the full setup. btw, nice wc parts you have chosen there.
cyrixMII300 is offline
post #3 of 7 Old 02-19-2006, 01:50 PM
1.7ghz
DrDeville's Avatar
Quoted: 0 Post(s)
Liked: 46
Hi Urufu,
The sticky Cyrix recommended will help you with general placement of pump, etc.
Regarding what you show, my suggestion is to move your radiator from the case's top to its rear, put a fan where you have your radiator now (but inside the case), and have them both exhausting--that's what I did.
My reasoning is hot air rises, and your processor is probably near the top rear, so that's where much of your hot air ends up. Getting that hot air out of your case is great, but blowing it through your radiator is not-so-great. So the combo I suggest gives you the best of both worlds.
In my setup, I accidentally blocked my top exhaust vent (Windoze XP disk), and case temps soared, even though I'm using a very low flow fan on the top. So it seems it's doing its job.
Hope this helps.
"The fault, dear Brutus, lies not with our stars, but our selves." - Shakespeare
"The ability to quote is a serviceable substitute for wit." - W. Somerset Maugham
DrDeville is offline
post #4 of 7 Old 02-19-2006, 03:51 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 223
I appologize for not explaining myself better, I'm very familiar with how the traditional WC setup works. I'm asking for more precise suggestions, i.e. "since your rad is up here you shoud put X here" etc. Like, where would be a good place to put my T-line seeing as the rad will actually be the highest point in the loop? I have plenty of room in the case for everything but the '77 heatercore (it's exatly 1/16th in. to wide to fit inside the drive rails in front ) so If I should place my pump somewhere besides the floor of the case thats doable. Is having the radiator so high in the loop going to be a problem for the D5 pump? Will I have trouble filling and bleeding with the rad at the top (btw, it won't fit on the back, it interferes with the wires)? I've seen a lot of rigs with the T-line at the bottom of the case right in front of the pump, is this sufficient or is it a bad idea? Stuff like that....
post #5 of 7 Old 02-19-2006, 04:01 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 71
any particular reason your not using a res instead of a t-line? Resevoirs tend to be easier to use to fill and bleed.
http://valid.x86-secret.com/show_oc.php?id=86957
Computer
/nm./: a device designed to speed and automate errors.winksmiley02.gif
There are 10 types of people in this world. Thos who can read binary and those who can't.
WARNING: Xoxide sells leaking resevoirs!!!!!!!!
Leprachuan is offline
post #6 of 7 Old 02-19-2006, 04:18 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 223
1: cheaper
2: less space
3: cheaper
4: less chance of a leak imo
post #7 of 7 Old 02-20-2006, 01:17 PM
Overclocker
Snerp's Avatar
Quoted: 0 Post(s)
Liked: 385
Originally Posted by Urufu_Shinjiro
1: cheaper
2: less space
3: cheaper
I agree...I found my res to be a total waste of money and a pain in the ass.
FAQ: Teflon Tape...USE IT!
OSAMT: "Member of OCN Songwriter and Musician Thread"
Proud Member of the OCN Mechanical Keyboad Club!
Snerp is offline
