Starting water cooling - Overclock.net
post #1 of 10 Old 02-21-2006, 08:39 AM - Thread Starter
4.0ghz
Lone136's Avatar
Quoted: 0 Post(s)
Liked: 66
For some time now I have wanting to water and until now I haven't been able to aford to, but do to Waxshop having a child on the way I'm getting some parts from him for a baby bed for his up coming child. He did offer the parts for I was just giving he the bed for free
Now since this will be my first go around with water cooling I was thinking about my past Electrical back ground and how we would control more then one light at a time on one switch.
I don't want to have worry about turning a pump on or fans to cool the water off for my CPU or GPU.
The idea behind this is that when you push your on/off button it would start your computer and the water pump and fans at the same time using 12volts DC supplied from the power supply.
I'm going to use a (single pole/single throw) Relay Coil. That will mean that you will have only one set of contacts. They would be Normally Open with no power to the 12-volt coil.
I will use a power plug from an old AT power supply that no longer works (I think we all have one of those) to bring the power inside the computer to the switch. This way I can use a regular computer power cord to power up the pump and fans. I will use the plug and make a pattern. Then I use that to cut my case. It will be a small hole maybe 1 ½†by ¾†at the bottom rear so I can then bolt power plug to the back.
So, now all I have to do is get the rest of the parts I need and starte the mod. I will still need to get the pumps tubbing and mis parts,but atleast now I have starting point.
Lone136 is offline
post #2 of 10 Old 02-21-2006, 08:53 AM
Blocksmith
fstfrddy's Avatar
Quoted: 0 Post(s)
Liked: 408
You can also buy relays tha fit in a pci slot, but if you are using a 12 volt pump you do not need it.
fstfrddy is offline
post #3 of 10 Old 02-21-2006, 09:01 AM - Thread Starter
4.0ghz
Lone136's Avatar
Quoted: 0 Post(s)
Liked: 66
I want to use a 120 volt pump, but turn it on with a 12 volt DC coil. I also have 2x 120mm 70 CFM fans that are 120volts. The point to all of this is, I don't want to use the PSU for any thing but turning the coil on.
Lone136 is offline
post #4 of 10 Old 02-21-2006, 10:30 AM
Blocksmith
fstfrddy's Avatar
Quoted: 0 Post(s)
Liked: 408
Yeah thats what the relays do they don't supply the power, just turn it on and off.
fstfrddy is offline
post #5 of 10 Old 02-21-2006, 10:36 AM
Jazino's Avatar
Quoted: 0 Post(s)
Liked: 139
is this what your looking for? http://cablecrazy.com/Merchant2/merc...Code=DDPWRPLNT
Overclock.net 10 Year Member
Jazino is offline
post #6 of 10 Old 02-21-2006, 12:53 PM - Thread Starter
4.0ghz
Lone136's Avatar
Quoted: 0 Post(s)
Liked: 66
Ya, something like that, but I plain to build my own
Lone136 is offline
post #7 of 10 Old 02-21-2006, 08:31 PM
733mhz
Quoted: 0 Post(s)
Liked: 12
http://cgi.ebay.com/ws/eBayISAPI.dll...category=80150
There is a good pump for you. 3/8" fittings.
Lone136 likes this.
Johnnie Walker is offline
post #8 of 10 Old 02-21-2006, 08:36 PM
New rig again :s
Quoted: 0 Post(s)
Liked: 497
I wouldn't get a fountain pump for that price, Instead get the DangerDen D5 pump. You can find them new under 70 usually.
Fold For Team 37726!! Get Started Here
Upgrades---> T7200 Core 2 Duo
Guide---> What Core 2 Duo Motherboard is right for me?
Projects---> Waterchiller Build
Rig 2---> P4 640 @ 4GHz, Asus P5P800-SE, 512MB crap, Sunbeam NUUO 550w
My Old Rig --->2.4AE @ 4.15GHz , semi Stable, yes 1.75GHz OC ...
wowza is offline
post #9 of 10 Old 02-21-2006, 09:09 PM - Thread Starter
4.0ghz
Lone136's Avatar
Quoted: 0 Post(s)
Liked: 66
Is 3/8 going to big enough for cooling my cpu and gpu?
Lone136 is offline
post #10 of 10 Old 02-21-2006, 09:12 PM
New rig again :s
Quoted: 0 Post(s)
Liked: 497
Yep, I am not a big fan of 1/2 due to the big tubing, but 3/8 should work just fine
wowza is offline
