79C i7 load under water? Help meh - Overclock.net
post #1 of 14 Old 06-10-2010, 02:09 PM - Thread Starter
Contagion's Avatar
Quoted: 1 Post(s)
Liked: 718
I just got my loop up and running, my video card temps are amazing, but my i7 temps are making me cry a bit.
Loop (Arrow points in flow direction):
DD-CPX1 Pump>Feser 480 Rad>DD MC-TDX CPU Block>MCW60 GPU Block>Micro Res
These temps are just a few degrees under what my Ven X kept it at (which was low 80s).
Contagion is offline
post #2 of 14 Old 06-10-2010, 02:11 PM
Intel Overclocker
F1ForFrags's Avatar
Quoted: 0 Post(s)
Liked: 170
It looks like a bad spread to me.
F1ForFrags is offline
post #3 of 14 Old 06-10-2010, 02:12 PM
*cough* Stock *cough*
Quoted: 0 Post(s)
Liked: 45
change inlet outlet tubes on your cpu waterblock. for sure that will help, but dunno how much, it's not so efficient block anyway.
i5 3570k | MSI Z77 MPOWER | 2x4gb 1600 Crucial | ZOTAC GTX 970 | 240gb SSD Crucial BX100 | IN WIN 303 | be quiet! STRAIGHT POWER 10 500W
prznar1 is offline
post #4 of 14 Old 06-10-2010, 02:13 PM
Quoted: 1 Post(s)
Liked: 473
May need to get a heavier duty block - I always saw the TDX as the perfect Dual core cooler.
But start by swapping your inlet/outlets
Intel:MainRig i7 2600K@4.5/Gigabyte Z68X-UD3H/16GB DDR3@1600/2xHD6990
Intel:Secondary Xeon x5650@4.4 1.35v/X58A-UD3R/12GB DDR3@1600/3xHD6970
AMD:HTPC 2400-BE/A7GM-S 2.0/2GB DDR2@855/HDMI
Server1ell R610 DualQuad/48GB@1333
Server2:HP Proliant DL360 G5 DualQuad/32GB@533
rpm666 is offline
post #5 of 14 Old 06-10-2010, 02:13 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 109
Rad not getting fresh cooler air from the outside?
Chimp Challenge Participant  1 Million+ Folding at Home points
skatpex99 is offline
post #6 of 14 Old 06-10-2010, 02:29 PM
1.3ghz
ltbob's Avatar
Quoted: 0 Post(s)
Liked: 7
did you try to reseat it?
new thermal paste kick old they tiny stuff before you buy a new block
ltbob is offline
post #7 of 14 Old 06-10-2010, 04:39 PM
Intel Overclocker
F1ForFrags's Avatar
Quoted: 0 Post(s)
Liked: 170
wut...
post #8 of 14 Old 06-10-2010, 04:43 PM
SniperXX's Avatar
Quoted: 0 Post(s)
Liked: 269
You have the flow backwards on the cpu block, dunno how much difference it would make.
Chimp Challenge Championship Team  Chimp Challenge 3 x Participant  5 Million+ Folding at Home points
SniperXX is offline
post #9 of 14 Old 06-10-2010, 04:50 PM - Thread Starter
Contagion's Avatar
Quoted: 1 Post(s)
Liked: 718
I re-did it. It dropped the temps a few degrees.
I suppose this block just isn't strong enough for 8 threads.
post #10 of 14 Old 06-10-2010, 05:09 PM
3.0ghz
lwesley's Avatar
Quoted: 0 Post(s)
Liked: 60
Dude, think you switched the tubes the other way round for your CPU block. The incoming tube should hit the middle of the block, not side.
Wes
Blameless likes this.
Core i7 920 @4.31ghz (HK3.0+MCR320Drive) [DT Air/CPU @ 13c idle, 45c IBT]
MSI GTX 295 Single PCB with EK 295 + MCR320 Drive + 1450rpmGT [DT Air/CPU @ 10c idle]
Asus R3E . Corsair TX850 . OCZ 12Gb 1333mhz RAM
lwesley is offline
