Bad First Water Cooling Experience(Turned Good!) - Page 2 - Overclock.net
post #11 of 22 Old 06-11-2010, 04:10 PM
1.7ghz
Sider's Avatar
Quoted: 0 Post(s)
Liked: 32
Originally Posted by chriskaz View Post
Quick question. What do you guys think of setting up rads like this. Not looking for the best temps.
You should always try to feed your rads fresh cool air. Not only will your second rad be getting hot air from the first rad but you have the first rad sucking in hot air from the case to begin with, making that configuration even worse.
I'm not a fan of the rad sandwich config to begin with but if you had to do it that way reverse the fans so they're pulling fresh into the case.
chriskaz likes this.
Sider is offline
post #12 of 22 Old 06-11-2010, 04:23 PM - Thread Starter
1.3ghz
chriskaz's Avatar
Quoted: 0 Post(s)
Liked: 9
Alright I will switch it around then. I can see how the hot air would really mess up the black ice on top. Was hoping to keep the air filter on the bottom of the 800d feeding the intake, and I didn't think it would be good to blow hot air into the case but that won't matter cause im wc anyway.
Chimp Challenge 2 x Participant
chriskaz is offline
post #13 of 22 Old 06-11-2010, 04:58 PM
1.3ghz
ltbob's Avatar
Quoted: 0 Post(s)
Liked: 7
200 liter PER HOUR!?!?! are you mad!
>.< atleast 200gph is recommended (757) lph go metric
ltbob is offline
post #14 of 22 Old 06-11-2010, 05:52 PM - Thread Starter
1.3ghz
chriskaz's Avatar
Quoted: 0 Post(s)
Liked: 9
I didn't feel that I needed a whole lot of flow with a single loop. Im actually surprised how well this loop is doing now that I look more closely. Id say at the very least, 1/2 of the flow is being diverted by looking at it.
200 Liters per hour is almost 1 gallon per minute, so this is where I should be round about.
chriskaz is offline
post #15 of 22 Old 06-11-2010, 07:15 PM
733mhz
Quoted: 0 Post(s)
Liked: 26
The pump is on the 'weedy' side. 200 litres per hour and only 1.2m head
http://www.specialtech.co.uk/spshop/...at=1631&page=1
US Gallon approx 3.8 litres vs UK gal = 4.5 litres
You are not getting 1 gallon per minute.
Even using the US gallon:
200 litres/hour = (200/3.8) = 52.63 gallons /hour
52.63 /60mins = 0.87 gallons / minute BUT this is with no restriction! Once you add CPU block and radiator and tubing it will be significantly less than 0.87 Gallons/ minute.
Teh Noob Slayer is offline
post #16 of 22 Old 06-11-2010, 07:40 PM - Thread Starter
1.3ghz
chriskaz's Avatar
Quoted: 0 Post(s)
Liked: 9
First Off, That cat in your avatar looks exactly like my cat..crazy.
Yea, I should have been more specific when I said about 1 gpm.
I figure I have very low pumping power when this res combo runs to spec.
Ironically, I get about the same in the pic (69c) only difference being is that test was ran at 4200 MHz w/ 1.52 v. My system runs at 3800 MHz w/1.29 v.
chriskaz is offline
post #17 of 22 Old 06-11-2010, 10:27 PM
333mhz
Quoted: 0 Post(s)
Liked: 6
hi
i am sorry to hear that. am newbie in water cooling too, i have almost same water kits as you, but i went for 655+swiftech res. they working great for me.
meshal300 is offline
post #18 of 22 Old 06-11-2010, 11:19 PM
AMD Overclocker
SwishaMane's Avatar
Quoted: 0 Post(s)
Liked: 106
Originally Posted by KRAZYTRUCKER View Post
The better choice would have been the xspc 750 combo but........don't knock xspc they make some quality stuff. You also got one of the most restrictive blocks on the market too. Xspc is designed for low restriction systems. Water cooling is like anything thing else, there is some trial and error. Don't be so hard on yourself. If the pump is bad return it and keep on going. Machinery fails like anything else. It will all be ok. Breathe in Breathe out.
Are you sure the rad is full? If its horizontal, or vertical with barbs down, you'll need to tip it to get it full and bubble(less)...
Personal best - 11,811 in 3DMark06 on 01/16/2016 socket 939 baby!
Proud elite member of the Socket 939 Appreciation Club.
SwishaMane is offline
post #19 of 22 Old 06-12-2010, 05:54 AM
4.0ghz
koooowweeee's Avatar
Quoted: 0 Post(s)
Liked: 57
can you not send the res/pump back? if your not doing crazy clocks it will be fine. especially with a rx360 witch i also have. once the pump is fixed you will get good temps its a cpu only loop after all
koooowweeee is offline
post #20 of 22 Old 06-12-2010, 07:37 AM
1.3ghz
ltbob's Avatar
Quoted: 0 Post(s)
Liked: 7
ltbob is offline
