MSI GTX 470 Warrenty With Water Cooling? - Overclock.net
post #1 of 6 Old 06-11-2010, 12:13 AM - Thread Starter
4.0ghz
metroidfreak's Avatar
Quoted: 0 Post(s)
Liked: 89
Not sure if this is the section to put this, but it has to do with WCing also.
Does anyone know how MSI treats RMAs on cards that have been water cooled? If anything goes wrong should I just put on the original HSF and shroud that it came with and hope for the best?
Also, what are some good VGA coolers or plates that won't run out my bank? (As you can see I'm new to water cooling lol)
metroidfreak is offline
post #2 of 6 Old 06-11-2010, 12:17 AM
Автомат Калашникова 47
88EVGAFTW's Avatar
Quoted: 0 Post(s)
Liked: 525
Dont tell them it was water cooled.
88EVGAFTW is offline
post #3 of 6 Old 06-11-2010, 12:21 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 89
So pretty much throw the the original shroud back on it. Thanks! What actual cooling block and other things would be good to go with?
post #4 of 6 Old 06-11-2010, 12:28 AM
88EVGAFTW's Avatar
Quoted: 0 Post(s)
Liked: 525
Yea you usually always RMA video cards just how they came when you got it. Are you asking for a GTX 470 water block? I personally LOVE the EK full cover blocks. My card right now with higher room temps stays around 45C-48C while gaming.
post #5 of 6 Old 06-11-2010, 12:49 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 89
Looks cool. How much are they? Generally, how much would an initial water cooling loop cost? Like just a basic one to cover my 470 and my i7
post #6 of 6 Old 06-11-2010, 04:14 AM
4.0ghz
xguntherc's Avatar
Quoted: 0 Post(s)
Liked: 259
Ya basically if you need to send any watercooled card in for RMA put the original heatsink back on and try to make it loook completely normal, don't remove any stickers or anything.
Keep every part, every screw. and when needed make it look brand new, put back together and RMA. I put all my screws and parts in a pill bottle and put in my eVGA box. so I have it all if ever needed
H20 Loop: Swiftech Apogee GTZ, Feser TFC360 RAD w/ 3 Scythe GT 1850's, MCP-655 D5 Vario, EK Multi-Option Res, Masterkleer 7/16 ID, DD "FatBoy" 1/2 Barbs, Killcoil & Distilled. 28c Idle, 39c Load, Danger Den GTX 480 Nickel+Copper Block. Google CR-48 biggrin.gif
Project HAF Water-Cooled Best Overclock, & There's More to Come http://valid.canardpc.com/show_oc.php?id=491589
camera.gifOfficial OCN Camera Club camera.gif |Nikon D40| |18-105mm f/3.5-5.6 VR||35mm f/1.8||55-200mm f/4-5.6 VR
xguntherc is offline
