Thermaltake Bigwater 745 Install - Page 2 - Overclock.net
post #11 of 12 Old 03-13-2006, 11:19 PM - Thread Starter
333mhz
Manco's Avatar
Quoted: 0 Post(s)
Liked: 6
Originally Posted by ShawnMcGrail
Well, It is a 955 and I'm pretty sure they can handle the heat.
As said before, Nothing can beat a custom setup, But the lapping you did to that block is beautiful!
What did you lap it to? Did you start a lower grit and work your way up, Or just start at like 800+ and move your way up?
Because either way, Its lookin' good!
Yeah lapping was easier than I expected. I started with 600, then 800, 1000, 1500 and then used some Brasso metal polish with a lint free cloth to make it shine! I could have went to 2000, but figured that was probably overkill.
When I lapped, starting at around 1000 I added a small drop of dish soap to go with the water so that it would move smoothly across the paper and not "catch".
Thanks for the props
Rukkee likes this.
Manco is offline
post #12 of 12 Old 03-14-2006, 03:54 PM
333mhz
Rukkee's Avatar
Quoted: 0 Post(s)
Liked: 8
Originally Posted by notdave
dude Bigwater is not big enough! , pump 2 small:withstupi ,block=cheap:withstupi ,tubing=tiny 1/4" junk :withstupi , get real water rig before you smoke that CPU your temp is 25-30C too high
I have the same kit , first off its 3/8ths tubing , second the block is fine, not the best , but certainly not junk ,third you think his load temps should be 32c with an intel?
I have mine installed externally , 25c idle 35c load ambient 24c .
+ rep manco nice install pics
Manco likes this.
Rukkee is offline
