Huge probelm with my W/C - Page 2 - Overclock.net
post #11 of 28 Old 03-24-2006, 10:10 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
Originally Posted by fstfrddy
you can't see the flow going to your reservoir?
nope water is not moving at all. when i put it all together like 3 weeks ago i can see water moving in reservoir, now its not
hanwinting is offline
post #12 of 28 Old 03-24-2006, 10:13 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
Originally Posted by busa
Yes...on/off. When filling system thru the res and using gravity to fill it as far as possible, Then turning on the pump, you won't get any flow thru the system until you crack a fitting to let the air pocket out. Not sure how this would have happened to your rig...I'm leaning more toward a failing pump. Doing this will also confirm that the pump is running or not. I would suggest removing the pump and testing it. Ever cleaned the pump?
yes i took it apart there is nothing inside. and i tested the pump. the water moved only if i put to reservoir higher than the pump.when i put it at the same level as the pump then the water is not moving atall.
post #13 of 28 Old 03-24-2006, 10:19 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 324
The pump is bad. The reason it flows when the res is higher is gravity and the pump is turning and letting the water thru it.
Stinger Slingers V5
insanity reigns
It's better to reign in hell than serve in heaven.
There is more to life than increasing its speed. - Mahatma Gandhi...guess he's not a member of Overclock.net
1 Million+ Folding at Home points
busa is offline
post #14 of 28 Old 03-24-2006, 10:19 PM
Blocksmith
fstfrddy's Avatar
Quoted: 0 Post(s)
Liked: 408
It sure sounds like the impeller is not turning, better take it apart and look again, Maybe it sucked up a peice of thread tape or something??
fstfrddy is offline
post #15 of 28 Old 03-24-2006, 10:20 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
u think so? i mean when i put it together i saw the water moving in reservoir for like a week and then it stopped
post #16 of 28 Old 03-24-2006, 10:29 PM
Blocksmith
fstfrddy's Avatar
Quoted: 0 Post(s)
Liked: 408
something is going on, these pumps are pretty simple, you may be able to fix it, it may just be touching somewhere (the impeller) fix that with a little sandpaper.
hanwinting likes this.
fstfrddy is offline
post #17 of 28 Old 03-24-2006, 10:30 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
the impeller is spinning. i think ..fix it with sandpaper how???
post #18 of 28 Old 03-24-2006, 10:31 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 324
So if it was running normally....then it never stopped running...just stopped pumping water? I'd have to say it failed somehow.
Stinger Slingers V5
insanity reigns
busa is offline
post #19 of 28 Old 03-24-2006, 10:32 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
ok guys this is important. i need to know if this is really a bad pump. if it is then i need to spend another 65 bucks to buy a new pump and took my system apart AGAIN! grrr i hate this
thnx for both of ur help
u two derserves 10rep each ^_^
post #20 of 28 Old 03-24-2006, 10:34 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 219
one more question..........
usually when there is a bubble in the loop, it usually moves back to reservoir rite?? buz mind doesnt there is a bubble by my CPU block and it just stays there
