wc build log - Page 18 - Overclock.net
post #171 of 178 Old 09-02-2006, 01:26 PM
PC Gamer
Renegade5399's Avatar
Quoted: 0 Post(s)
Liked: 224
I try to keep my room at the same temps as the DataCenter at work. Between 62 and 68°F. At 75°F an alarm goes off here at work to let us know the DataCenter is too hot. That is what I base my beliefs off of as we never have a hardware issue that is heat related. 75°F is just a tad too warm and temps in the low 40's is good for that ambient. Get the temp down to around 68-70°C and you'll be pleasantly surprised at the drop you'll see in temps system wise.
My Sauce Is Much 13373|2 Than Yours
I am made of Win.
Renegade5399 is offline
post #172 of 178 Old 09-02-2006, 01:31 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 71
I tried to set it at 65 already, it goes down to 39-40
4ghz Proof
3Dmark06: 20K
Laptop spec:
Lenovo T400; 2.26ghz p8400, 3gb DDR3, 160gb 7200RPM, ATI 3470, LED Screen+webcam, fingerprint reader, intel 5300 wifi/BT, 9 cell battery, Windows 7 ultimate, SB Audigy 2ZS
Best free software for Windows 7 x64/x86.
The day Microsoft makes something that doesn't suck is probably the day they start making vacuum cleaners.
pcharouz is offline
post #173 of 178 Old 09-02-2006, 01:33 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 224
Do you have a thermometer in your room somewhere? I never trust the one on my thermostat. And 39-40 again, for what you are running equipment wise, is great.
I am made of Win.
post #174 of 178 Old 09-02-2006, 01:44 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 71
I dont have a thermometer, and are you saying I have bad equipment!?!? LOL
I think I should be getting better temps, another reason for that is that I have the rad outside my case, and there is one more thing, your right 39 load is not that bad, but it sits at 37-38 idle, which is really wierd
4ghz Proof
3Dmark06: 20K
Laptop spec:
pcharouz is offline
post #175 of 178 Old 09-02-2006, 01:56 PM
(ノ◕ヮ◕)ノ*:・゚✧·★゜・。☆゜。 ・゚
CyberDruid's Avatar
Quoted: 0 Post(s)
Liked: 2585
Good advice there about your temps being okay for ambient. I have a Storm, D5 and 110 CFM 120mm and good-sized transmission cooler for a Rad--I get 42-43C with an ambient of 75C.
Because I can't freeze my wife and kids by cranking the thermostat down I am satisfied that is good enough.
August 13th, 2011 sad-smiley-002.gif Happy trails, may we meet again.
CyberDruidPC is History
CyberDruid is offline
post #176 of 178 Old 09-02-2006, 02:19 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 71
You guys were right, I set the ac to 70 again, and I noticed that the vent in my room isnt blowing much air, so I closed all the other ones in my house, and my cpu idle is 35, load 37(folding)
But still, people get 28-32 idle, why cant I get that?
4ghz Proof
3Dmark06: 20K
Laptop spec:
pcharouz is offline
post #177 of 178 Old 09-02-2006, 03:50 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 224
Hot chip stepping, amount of volts you are using to maintain your OC, too much AS5, block not ultra smooth on the bottom, concave or convex IHS. I could keep going if you'd like, but there's a lot of reasons why. Going "naked" (removed IHS) can yield up to a 5°C drop in temps at load. In some rare cases (like mine) it can yield up to 10°C drop. My NewCastle ran at 55°C load until I removed the IHS and now at the same settings, it doesn't break 45°C load. I put the IHS on a piece of glass and it was anything but flat. Not to mention AMD uses too much thermal paste under the lid. The top of the chip was covered in the stuff.
pcharouz likes this.
I am made of Win.
post #178 of 178 Old 09-02-2006, 03:53 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 71
thanks, rep +
I am using 1.5v and I acctually think I might be using too litle as5, and my stepping does suck the max I can overclock is 2.93, and 2.82 24/7
4ghz Proof
3Dmark06: 20K
Laptop spec:
pcharouz is offline
