[Official] XSPC Rasa 750 RS/RX120/240/360 Kit Club - Page 259 - Overclock.net
post #2581 of 13773 Old 01-18-2011, 10:14 AM
Overclocker
Quoted: 0 Post(s)
Liked: 17
Originally Posted by Bal3Wolf View Post
if my problems are sorted i will try them all again to get my best temps tho i dont have any as5 now i was borrowing some befor to try. I hope xspc will send me a new block and it will work right and get good temps cause this one even clean does not seem to be working much better i do have alot of bubbles tho.
I still have to get some water for mine.. And i'll order the kill coil probably today or tomorrow..
"I REJECT YOUR REALITY, AND SUBSITUTE MY OWN!" - Adam Savage
What's a CD? Is that one of those things people used before they invented flash drives?
dembo1305 is offline
post #2582 of 13773 Old 01-18-2011, 10:39 AM - Thread Starter
Welcome Back, Commander.
Quoted: 0 Post(s)
Liked: 690
Any new members that posted pics so I can add?
Flick of the wrist.
15 Million+ Folding at Home points
mbudden is offline
post #2583 of 13773 Old 01-18-2011, 10:57 AM
733mhz
man00's Avatar
Quoted: 0 Post(s)
Liked: 5
Originally Posted by chano305 View Post
Are they sending a replacement without you having to send yours first? I contacted support, they told me to send mine in so they can check it, then they'll send me a replacement if needed. But that'll take my computer out of commission for who knows how long...
Same thing they told me about my pump send it in they check it out. I mean thats about all they have to do but think I will take another route buy else where.
man00 is offline
post #2584 of 13773 Old 01-18-2011, 11:33 AM
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Originally Posted by dembo1305 View Post
So would the overall verdict be that other than buying more paste I am probably better off to just use my AS5? Some manufacturers will include some decent paste with their products so I didn't know what came with this one..
Unless you really do want to buy new/better paste. Not much option other than Shin Etsu x23-7783D (some say hard to apply) and Indigo Extreme (expensive and not easy to reflow on an AMD chip). Others will be around the same numbers as the AS5. I'd say use up your AS5 and take it from there.
Validation - Updated as of 4/21/12
Chimp Challenge Participant
Kahbrohn is offline
post #2585 of 13773 Old 01-18-2011, 01:32 PM
Overclocker
Quoted: 0 Post(s)
Liked: 17
Ok how do I tell which is the in and which is the out on the radiator?
post #2586 of 13773 Old 01-18-2011, 01:34 PM
Norlig's Avatar
Quoted: 0 Post(s)
Liked: 119
It doesnt matter, Both ports can be used as a inlet and a outlet
dembo1305 likes this.
Norlig is offline
post #2587 of 13773 Old 01-18-2011, 01:39 PM
Overclocker
Quoted: 0 Post(s)
Liked: 17
Alright thanks.. +rep
post #2588 of 13773 Old 01-18-2011, 01:57 PM
Zaiber's Avatar
Quoted: 0 Post(s)
Liked: 18
This is a really bad pic, but this is how it turned out!
Zaiber is offline
post #2589 of 13773 Old 01-18-2011, 02:03 PM
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Nice... now change your sig!!! Still says H50.
Kahbrohn is offline
post #2590 of 13773 Old 01-18-2011, 02:07 PM
Zaiber's Avatar
Quoted: 0 Post(s)
Liked: 18
Done!
Zaiber is offline
