[Official] XSPC Rasa 750 RS/RX120/240/360 Kit Club - Page 47 - Overclock.net
post #461 of 13773 Old 12-18-2010, 10:35 AM
Quoted: 0 Post(s)
Liked: 960
months or not it usualy happens and has been documented by lots of users and a pain to clean up later on. But jonesy you could be ok just watch your temps if you see them starting to get worse and your amb haset went up its probly gunk in your blocks. And jonesy i thk its funny your name says I7 but you have a amd.
20 Million+ Folding at Home points  Foldathon Folder - 2013 Participant  Chimp Challenge Participant X4  BOINC Pentathlon Participant x2
Bal3Wolf is online now
post #462 of 13773 Old 12-18-2010, 10:39 AM
4.0ghz
Jonesey I7's Avatar
Quoted: 0 Post(s)
Liked: 128
I started with the baddest i7 on ocn back last year when I joined, then I sold it to jktown and downgraded a little on the processor, upgraded highly on the video card as all I do is game.
Link to the sale thread with benches...
http://www.overclock.net/full-systems/751617-baddest-i7-920-ocn-1300-sold.html
2 Million+ Folding at Home points
Jonesey I7 is offline
post #463 of 13773 Old 12-18-2010, 11:05 AM
Quoted: 0 Post(s)
Liked: 960
Yea that is a nice i7 lol i wish mine did that but 4200 on 1.31 aint bad.
post #464 of 13773 Old 12-18-2010, 11:16 AM
333mhz
urdeath007's Avatar
Quoted: 0 Post(s)
Liked: 2
So the good EVGA member I'm purchasing my gtx-480 ek acetel-nickel block from recommends replacing the "1.0mm and 1.5mm pads"
Not 100% sure on where these 1mm & 1.5mm pads are as on frozen cpu I find http://www.frozencpu.com/products/7863/thr-49/EK_Replacement_Liquid_Block_Thermal_Pad_60mm_x_50mm_x_05mm_.html thought it's not even the minimum pad size? Thoughts on that?
urdeath007 is offline
post #465 of 13773 Old 12-18-2010, 11:34 AM
[Adz]'s Avatar
Quoted: 0 Post(s)
Liked: 182
If you're going to be putting it together again, you'll to get new pads. Section 4 here tells you how thick each section needs to be. The 0.5mm won't be enough.
If you can't find it elsewhere, you could always buy directly from EK: http://www.ekwaterblocks.com/shop/accessories/thermal-compounds/thermal-pads.html
Ͼ(ಠ_ಠ)Ͽ
"You met me at a very strange time in my life"
[ ace8uk ] Nah, knowing my luck, if I worked for MacLaren, I'd be put on the push chair team.
[ -iceblade^ ] You sir are composed of own with a side of win.
"Every time you make a typo, the errorists win"
Migration_Sherpa
[Adz] is offline
post #466 of 13773 Old 12-18-2010, 11:36 AM
333mhz
urdeath007's Avatar
Quoted: 0 Post(s)
Liked: 2
Ordered my Rasa 360 kit. Busy for the day so cya all l8rs.
post #467 of 13773 Old 12-18-2010, 11:55 AM
4.0ghz
Jonesey I7's Avatar
Quoted: 0 Post(s)
Liked: 128
Updated pics...... FINALLY
Please excuse the crappy phone pics.
post #468 of 13773 Old 12-18-2010, 11:57 AM
[Adz]'s Avatar
Quoted: 0 Post(s)
Liked: 182
Temps?
Ͼ(ಠ_ಠ)Ͽ
Migration_Sherpa
[Adz] is offline
post #469 of 13773 Old 12-18-2010, 11:58 AM
WaterCooler
DullBoi's Avatar
Quoted: 0 Post(s)
Liked: 23
Hi, to everyone wanting to use dye and UV/Colour fliuds.
This is what happened to my clear tubing after two weeks of Feser UV Blue.
In my update, Link 2, you can see Promachill UV Blue tubing, very sturdy and has a nice bending curve . No gunk neither, I had blue gunk form in my RX240 rad after just two weeks of use, imagine 2 months eek.gif
No thanks.
Mbudden, go for a Haf-X if you dont mind a big case smile.gif You could always fit a 360mm rad in there and I am sure there is space for another 240mm tongue.gif
Chimp Challenge Participant  10 Million+ Folding at Home points
DullBoi is offline
post #470 of 13773 Old 12-18-2010, 11:59 AM
4.0ghz
Jonesey I7's Avatar
Quoted: 0 Post(s)
Liked: 128
Originally Posted by [Adz];11693144
Temps?
Those top two muti colored ones were the ones on my mega, figured id put them to good use as they are exact cfm's as fans with kit. Temps at 4.3ghz at 1.52v bios +llc (1.56v under load)..... max temp 48c, 44c with window open. Max temp on 6870 1 hour occt..... 48c, max in game 2 hours bfbc2 43c.
