[Official] XSPC Rasa 750 RS/RX120/240/360 Kit Club - Page 758 - Overclock.net
post #7571 of 13773 Old 05-27-2011, 04:55 AM
4.0ghz
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Send a message via AIM to Kahbrohn
I am seriously thinking about taking the rad out of the case. A good XSPC stand, some extra tubing... exchange the YL HS fans for something else (AP-15's maybe) and I should see a lowering of temps on the CPU. Then, slap some exhaust fans in the area that the rad is in and case temps should come down a bit. Maybe use the swapped out YL's for this. I am expecting my Accelero EXTREME Plus GPU cooler any moment soon so GPU is taken care of.
Just need to figure out the "logistics" of the external rad fan wiring and such.
Validation - Updated as of 4/21/12
Kahbrohn is offline
post #7572 of 13773 Old 05-27-2011, 05:37 AM
WaterCooler
ezveedub's Avatar
Quoted: 0 Post(s)
Liked: 137
Send a message via AIM to ezveedub
Originally Posted by Kahbrohn;13653490
Hehehehe... we have been lucky this past week. It's been raining all the time so temps have remained fairly cool mainly in the low and up to the mid 80's*F (27-29*C for you non-fahrenheit people). I remember last summer was hot-hot-hot. At least my rig is on the desk with the rear exhaust facing the window. When I closed the window at night and turned the A/C on, that corner of my work area would get hot real fast. That was before the water cooling. I will see how it really goes this year.
You guys in Florida just have way too much humidity.
I figured it would be rainy there now. Typical PR summer. Gotta get down there soon. Its been a while.
ezveedub is offline
post #7573 of 13773 Old 05-27-2011, 05:38 AM
WaterCooler
ezveedub's Avatar
Quoted: 0 Post(s)
Liked: 137
Why would you take the rad out? You have high case temps?
ezveedub is offline
post #7574 of 13773 Old 05-27-2011, 08:30 AM
4.0ghz
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Mid/high 40's when gaming. Seen low 50's on hotter days. High 30's, low 40's when doing normal browsing and stuff. Expecting all those to go up a bit during the hotter summer days coming around the corner.
When the new GPU cooler comes (wife won't let me but your card's dag nabit!), I believe it will cool the GPU but blow that hot air into the case itself and obviously raising the case temp a bit. That in turn will be sucked in by the rad fans when cooling the CPU.
To be honest, not even sure if those temps are good or not or if my assumptions are correct. Common sense say's yes...
Kahbrohn is offline
post #7575 of 13773 Old 05-27-2011, 10:18 AM
2.4ghz
Necrodox's Avatar
Quoted: 0 Post(s)
Liked: 12
I'm trying to mount my RX360 radiator in the back of my HAF-X case, I want to get the fans running in a push/pull configuration.
I already know how I'm going to mount it all, the problem is that I don't know where I can find a screw that is long enough. I'll need a 10-12inch screw, roughly.
I also need a screw sleeve (black if possible), anyone have an idea in regards to where I can find a screw like this? Been searching online but having some trouble finding the screw.
Necrodox is offline
post #7576 of 13773 Old 05-27-2011, 10:21 AM
The Computer Guy
AMOCO's Avatar
Quoted: 0 Post(s)
Liked: 429
Try your local hardware store,Like Home Depot,Lowes,Ace, & True Value.
Laptop:
HP 2000-2c29WM 15.6-Inch Laptop PC (Black Licorice) 1.7GHz AMD E2-1800 Processor / 8GB DDR3 RAM Memory / 240GB SanDick SSD Plus / Windows 10
Mobile Devices:
LG Stylo 2,,,Nougat 7.0..
Carriers:
Sprint
AMOCO is offline
post #7577 of 13773 Old 05-27-2011, 10:28 AM
WaterCooler
ezveedub's Avatar
Quoted: 0 Post(s)
Liked: 137
A 10-12 inch screw?? Not sure about that, but you can get hardware from McMaster-Carr online.
ezveedub is offline
post #7578 of 13773 Old 05-27-2011, 11:59 AM
4.0ghz
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Not going to doubt you know what you are doing... but... what are you planning on doing??? 10-12" screw sounds awfully long and even unstable!
Kahbrohn is offline
post #7579 of 13773 Old 05-27-2011, 12:14 PM
WaterCooler
Jobotoo's Avatar
Quoted: 0 Post(s)
Liked: 58
The Gentle Typhoon 2150 Group Buy is almost over, so you may want to take advantage of it before it is too late. They are $9 for the barebones model. These are a bit faster than the AP-15's, so with a controller you can dial them down, or up. And the price seems awesome to me.
Kahbrohn likes this.
Jobotoo is offline
post #7580 of 13773 Old 05-27-2011, 12:24 PM
4.0ghz
Kahbrohn's Avatar
Quoted: 0 Post(s)
Liked: 86
Yeah, I know... thanks for the reminder.
Kahbrohn is offline
