[Official] XSPC Rasa 750 RS/RX120/240/360 Kit Club - Page 922 - Overclock.net
post #9211 of 13773 Old 08-06-2011, 03:55 PM
333mhz
Cwolfer's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by n3tr0m;14489290
Cooling both of them and your CPU, or just the GPU's? I think you need a slightly more powerful pump to do all. Though i might be wrong, i'm not sure what that kit is capable of tongue.gif
Just the gpus. I'm watercooling mostly to reduce noise rather than to over clock (although I will oc something once it is wcd), so I'm in no rush to wc the CPU.
Cwolfer is offline
post #9212 of 13773 Old 08-06-2011, 04:33 PM
Good news everyone!
Boyboyd's Avatar
Quoted: 0 Post(s)
Liked: 531
Originally Posted by n3tr0m;14489025
Need a little bit of help here guys, i got the XSPC Rasa 750 RS360 kit. I'm running a Intel Core i7 2600k at 4,8GHz at 1,395v, and my temperatures are high from what I can say. They jumps up to arround 70-85*C when doing a normal Prime95 run (Blend). And they constantly jumps from 70 and then to 80 every 2-3 seconds. I'll upload a picture so you can see how my system looks like, maybe that will help you understand why my temperatures are that high ..
Also, will there be any difference if I pull air in from the top where the radiator is? Instead of pulling air out of the case (that's how my setup is now)
Loop = Pump - Radiator - CPU - Reservoir
In a one block system the loop order doesn't matter.
Did you take both sheets of protective plastic off the CPU block?
7 Million+ Folding at Home points
Boyboyd is offline
post #9213 of 13773 Old 08-06-2011, 07:19 PM
WaterCooler
n3tr0m's Avatar
Quoted: 0 Post(s)
Liked: 0
Both of the protective plastic sheets is off. My temperatures did drop a little when i turned the fans to take cold air from outside the case and then into it with Push-Pull. At 4,8 Ghz with 1,430v it idles at 41,75*C average, and 74*C on load with Prime95 Blend, this good?
n3tr0m is offline
post #9214 of 13773 Old 08-06-2011, 10:54 PM
333mhz
Busyhand's Avatar
Quoted: 0 Post(s)
Liked: 2
I get 65c with 1.472 volts @ 4.8Ghz with push-pull from inside case to outside. I did lap my block though and I am using AS5. I might try a different paste down the road. My idle temps are 25c
I am also using 5 Gentle Typhoon AP-15 fans atm.
Busyhand is offline
post #9215 of 13773 Old 08-06-2011, 11:26 PM
333mhz
Busyhand's Avatar
Quoted: 0 Post(s)
Liked: 2
Originally Posted by Cwolfer View Post
Hi guys,
So I just purchased an rx360 kit from http://www.jab-tech.com/XSPC-Rasa-75...t-pr-4780.html to water cool my HD 6990 (I bought the powercolor one with the water block already attached).
I was actually thinking about getting a 6990 +block and selling my GTX480 with block or option 2, pick up another GTX480 and block. Are you running the 6990 with triple screens?
Busyhand is offline
post #9216 of 13773 Old 08-07-2011, 11:25 AM
Extreme Cooler
Matt26LFC's Avatar
Quoted: 0 Post(s)
Liked: 61
Hey guys took apart my block as some of you know I wasn't happy with my temps, now its apart it does look quite messy! I've got pics just can't upload yet, what's the best way to clean the block? Links or descriptions would be great thanks.
Pics to come
Cheers
Matt
Matt26LFC is offline
post #9217 of 13773 Old 08-07-2011, 11:32 AM
333mhz
Frontsidebus's Avatar
Quoted: 0 Post(s)
Liked: 6
My tubing is starting to turn cloudy and lights up yellow when I put a torch to it. Water in the res and the res itself in still crystal clear though.
I've read here that the stuff that comes with the Rasa kit is rubbish so I'll just get some decent stuff when I add my GPU to the loop.
Error 482. Somebody shot the server with a 12 gauge.
Frontsidebus is offline
post #9218 of 13773 Old 08-07-2011, 11:33 AM
Eagle1337's Avatar
Quoted: 0 Post(s)
Liked: 241
Originally Posted by Frontsidebus;14497000
My tubing is starting to turn cloudy and lights up yellow when I put a torch to it. Water in the res in still crystal clear though.
That's common for the tubing
Sent from my GT-I9000M using Tapatalk
Eagle's Video Playback Guide
Steam: Deadly55 (will come up as Super Emo Ninja Kamikaze Ninja Prinny or Eagle1337) Origin: Deadly55 Xfire: Deadly55
Eagle1337 is online now
post #9219 of 13773 Old 08-07-2011, 11:38 AM
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
My tubing is starting to turn cloudy and lights up yellow when I put a torch to it. Water in the res ans the res itself in still crystal clear though.
Same here, I had the same problem with my tubeing, just get some coloured tubeing thumb.gif
PSN: ATO3FIX
STEAM: Atomfix
Chimp Challenge 2 x Participant
Atomfix is offline
post #9220 of 13773 Old 08-07-2011, 11:41 AM
1.7ghz
Vandal4126's Avatar
Quoted: 0 Post(s)
Liked: 4
Yeah heard the RASA tubing does that, Invest in some primochill, I ordered 7ft with my rasa kit.
Vandal4126 is offline
