High-End Watercooling Setup - Page 4 - Overclock.net
post #31 of 78 Old 12-26-2010, 06:58 PM
2.4ghz
kevink82's Avatar
Quoted: 0 Post(s)
Liked: 20
Personally i wouldnt recommend a mcp355 and a modified top is even worst, the failure rate is too high.
I went through 2 and i just gave up, first one happen after 2 weeks with a xspc top the pump would not start priming the water unless u give it a good shake and sometimes it will work, second one died in 24 hrs and its just dead.....
I ended up with ek4.0 and its been doing great, its cheap does a good job, does not run as hot as mcp355 as well. If u dont like ek then go for mcp655 that is a great pump i regret selling mine...
kevink82 is offline
post #32 of 78 Old 12-26-2010, 07:05 PM
Fold Among Us
Quoted: 0 Post(s)
Liked: 425
You sure you had everything hooked up correctly and nothing was impeding the flow?? There are MANY people on here running the MCP355 with aftermarket top without any problems. Honestly you are the first person I've seen with a complaint about it but I'm glad you like your new pump. I have the OCZ version of your pump (pretty much the same exact thing) and it works like a champ for me.
skull.gifFolding Team: The Misfitsskull.gif
SIX TIME CONTINUOUS TEAM COMPETITION CHAMPIONS
VW_TDI_02 is offline
post #33 of 78 Old 12-26-2010, 07:14 PM
It's still almost enough.
Chunky_Chimp's Avatar
Quoted: 0 Post(s)
Liked: 722
There are some older batches of DDC pumps that really didn't last long, he may have had tremendously bad luck.
Chunky_Chimp is offline
post #34 of 78 Old 12-26-2010, 07:18 PM
Fold Among Us
Quoted: 0 Post(s)
Liked: 425
Makes sense. I've only been around here for a few months biggrin.gif They've been pretty solid since I been here.
post #35 of 78 Old 12-26-2010, 07:20 PM
Security Sleuth
grizzlyblunting's Avatar
Quoted: 0 Post(s)
Liked: 13
get the better EK cpu block too if you are going to go "high end"
grizzlyblunting is offline
post #36 of 78 Old 12-26-2010, 07:22 PM
4.0ghz
metroidfreak's Avatar
Quoted: 0 Post(s)
Liked: 89
Why dont you just buy the 360 Rasa kit, the gpu block and the green tubing as save yourself some money. There can't be THAT much of a difference can there?
metroidfreak is offline
post #37 of 78 Old 12-26-2010, 07:28 PM
Fold Among Us
Quoted: 0 Post(s)
Liked: 425
The difference between the Rasa and EK block is maybe 1C in favor of the EK block. It's up to the OP if he's willing to spend $40 for that much gain.
Not a bad idea but I'm not really sure about the pump in those kits. I'm not saying it's bad but I don't really know much about it. It is a solid set for $149.99.
post #38 of 78 Old 12-26-2010, 07:36 PM
Mongol's Avatar
Quoted: 0 Post(s)
Liked: 225
Is that EK block better than the HK 3.0? Never did see a single recommend.
GRENADE ALERT!!! GRENADE IN THE HOUSE! ABORT!! ABORT!!!
Mongol is offline
post #39 of 78 Old 12-26-2010, 07:36 PM
3.5ghz
matrices's Avatar
Quoted: 0 Post(s)
Liked: 34
I have not read all 4 pages of this thread, but one sure way to save money is not to get a motherboard block. Doesn't really serve any purpose unless you are driving some truly extreme volts.
"The nationalist not only does not disapprove of atrocities committed by his own side, but he has a remarkable capacity for not even hearing about them." - George Orwell (Eric Blair)
matrices is offline
post #40 of 78 Old 12-26-2010, 07:38 PM
Fold Among Us
Quoted: 0 Post(s)
Liked: 425
Both the Rasa and EK blocks are better then the Heat Killer. The Heat Killer is still a great block but with the EK at the same price and performing better and the Rasa being much cheaper and also performing better it really doesn't get many recommendations :/ Still a great block though.
