Anyone with XSPC dual res chime in please. - Overclock.net
post #1 of 17 Old 01-09-2011, 05:30 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 160
Just wondering if the front letters "XSPC" is painted on or is it a cut out.
Tennobanzai is offline
post #2 of 17 Old 01-09-2011, 05:44 PM
3.5ghz
Quoted: 0 Post(s)
Liked: 106
PulkPull is offline
post #3 of 17 Old 01-09-2011, 05:45 PM
4.0ghz
kingofyo1's Avatar
Quoted: 0 Post(s)
Liked: 53
its a raised / glued on metal extension of the acryllic black board its on.
1 Million+ Folding at Home points
kingofyo1 is offline
post #4 of 17 Old 01-09-2011, 05:48 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 160
Can it be taken off?
post #5 of 17 Old 01-09-2011, 06:03 PM
5.0 GHz Club
charliehorse55's Avatar
Quoted: 0 Post(s)
Liked: 778
Not easily, and once you do, it will most likely be permanent.
charliehorse55 is offline
post #6 of 17 Old 01-09-2011, 06:06 PM
3.0ghz
sgilmore62's Avatar
Quoted: 0 Post(s)
Liked: 42
If you look at the backside of the plate you will see that it is stamped not glued on or separate.
Tennobanzai likes this.
sgilmore62 is offline
post #7 of 17 Old 01-09-2011, 06:10 PM
733mhz
massy086's Avatar
Quoted: 0 Post(s)
Liked: 13
maybe try turn the plate back to front and paint it to what ever color you want
massy086 is offline
post #8 of 17 Old 01-09-2011, 06:11 PM - Thread Starter
Quoted: 1 Post(s)
Liked: 160
Ouch. I just put in a order for it...Hopefully I can at least get rid of the color so it's all black..
Good idea
post #9 of 17 Old 01-09-2011, 06:15 PM
733mhz
massy086's Avatar
Quoted: 0 Post(s)
Liked: 13
maybe fill it and sand smooth then paint not too hard im going to have to do the same when i get mine boo hoo
massy086 is offline
post #10 of 17 Old 01-09-2011, 06:17 PM
5.0 GHz Club
Quoted: 0 Post(s)
Liked: 778
You could also manufacture your own faceplate for it, it's a very simple design and it would be easy to make from a small piece of sheet aluminum. Then you could also change the shape of the hole, or remove it completely. You also won't have a reversed imprint of the XSPC logo on the front.
