H50 Am3 high temps? - Overclock.net
post #1 of 6 Old 02-02-2011, 05:40 AM - Thread Starter
1.7ghz
Coldplayer's Avatar
Quoted: 0 Post(s)
Liked: 2
I got a corsair H50 as i needed space for more ram/ram cooler and i went from a noctua NHU12P (1 fan) to the Corsair H50 push/pull. And my temps are about 4-5 degrees worse. I knew that the h50 wouldn't be that great but i though push pull at least it'd be able to keep up with my old noctua.
Are there any common installation mistakes or anything like that which would hinder the h50 performance?
Cheers
Also i seem to have got 2 retention brackets for am3 in the h50 package is there any difference between using
http://t2.gstatic.com/images?q=tbn:A...Xb2oDnwTnQ&t=1
or
http://www.legitreviews.com/images/r...ir_h70_019.jpg
Coldplayer is offline
post #2 of 6 Old 02-02-2011, 05:43 AM
The Computer Guy
AMOCO's Avatar
Quoted: 0 Post(s)
Liked: 429
try re-seating the cpu block.
Laptop:
HP 2000-2c29WM 15.6-Inch Laptop PC (Black Licorice) 1.7GHz AMD E2-1800 Processor / 8GB DDR3 RAM Memory / 240GB SanDick SSD Plus / Windows 10
Mobile Devices:
LG Stylo 2,,,Nougat 7.0..
Carriers:
Sprint
Overclock.net 10 Year Member
AMOCO is offline
post #3 of 6 Old 02-02-2011, 07:33 AM - Thread Starter
1.7ghz
Coldplayer's Avatar
Quoted: 0 Post(s)
Liked: 2
just did that to no avail.
post #4 of 6 Old 02-02-2011, 01:22 PM
1.3ghz
paceee's Avatar
Quoted: 0 Post(s)
Liked: 13
make sure air flow goes right to left (blowing out the back)
paceee is offline
post #5 of 6 Old 02-02-2011, 01:26 PM
4.0ghz
Clairvoyant129's Avatar
Quoted: 0 Post(s)
Liked: 135
It's normal. You were right to expect mediocre performance.
Clairvoyant129 is offline
post #6 of 6 Old 02-02-2011, 03:00 PM
3.5ghz
mekaw's Avatar
Quoted: 0 Post(s)
Liked: 30
yeah H50 isn't the best thing, it's on par or worse than D14.
I went from H50 > D14 > H70
mainly H50 wasn't cutting it and D14 i aboslutely loved but took a lot of space and hard to work around in. H70 I got a really good deal through a friend who works at distributor
mekaw is offline
