EK Club - Page 1667 - Overclock.net
 1Likes
post #16661 of 21284 Old 07-30-2016, 02:05 AM
Lays's Avatar
Quoted: 0 Post(s)
Liked: 20
Originally Posted by 0ldChicken View Post
I wouldn't think it would happen that fast but using silver and nickel together is asking for corrosion issues. I believe it's supposed to eat the plating, or at least pit/flake it
edit: this must be the ltt page tongue.gif
So the only solution would be to re-fill the loop, get anti corrosive of some sort and a biocide and get rid of the kill coil?
Is there any way I can clean the block out without taking it apart? I wouldn't be surprised if that voids the 1080's warranty as well, since it's a factory installed block.
EDIT:
So my old nickel acetal universal GPU block is fine on the inside.. And I'm using the SAME loop.
Lays is offline
post #16662 of 21284 Old 07-30-2016, 02:14 AM
Vindicare's Avatar
Quoted: 0 Post(s)
Liked: 1
use a good premix like EK-Ekoolant EVO CLEAR
Vindicare is offline
post #16663 of 21284 Old 07-30-2016, 03:05 AM
Quoted: 0 Post(s)
Liked: 17
Waterblock Monoblock for Rampage V Edition 10 avalaible this monday
Waiting for Full Board
tistou77 is offline
post #16664 of 21284 Old 07-30-2016, 07:07 AM
Ladies, Please, One at a Time
TheCautiousOne's Avatar
Quoted: 0 Post(s)
Liked: 318
TheCautiousOne is offline
post #16665 of 21284 Old 07-30-2016, 07:25 AM
Quoted: 2 Post(s)
Liked: 675
IT Diva is offline
post #16666 of 21284 Old 07-30-2016, 07:26 AM
Retired Staff
DarthBaggins's Avatar
Quoted: 3 Post(s)
Liked: 90
DarthBaggins is online now
post #16667 of 21284 Old 07-30-2016, 07:50 AM
nVidia Enthusiast
fbmowner's Avatar
Quoted: 0 Post(s)
Liked: 10
I am about to put together a full EK loop, but I am seeing what some people in the forums have to say about what I chose or I am waiting to hear from someone that I forgot something! I mean the EK kit someone has suggested is a great price vs the $500 I am getting ready to spend, although my choices increase my price a good amount based on the D5 pump I picked, and the fittings. Feel free to point me in another direction if I am going down the wrong path! I envy you all! =P
fbmowner is offline
post #16668 of 21284 Old 07-30-2016, 08:05 AM
WaterCooler
0ldChicken's Avatar
Quoted: 0 Post(s)
Liked: 44
damn, that's not good. @Benjiw who else was having issues with this? I can't find anything in seahawk club/ek club or wc club
0ldChicken is offline
post #16669 of 21284 Old 07-30-2016, 09:05 AM
Quoted: 0 Post(s)
Liked: 318
post #16670 of 21284 Old 07-30-2016, 09:22 AM
EKWB Forum Support Representative
Quoted: 0 Post(s)
Liked: 279
Originally Posted by AllGamer View Post
yes, I like the clear plexi as well, but for the new kind the only have the frosted version.
I found some of the old versions with the 3 screws, instead of 1 screw, interesting they call the old type "Terminal" and the new type "Bridge"
Which brings me to the new question...
So I got 2 of these beauties, looking at the close up pictures, it shows they are using the 3 screws, which should match the old Terminal type.
Does it matter at all if I use the CSQ Bridge type with 1 mount screw, or the old Terminal type with 3 mount screws?
Warning: Spoiler! (Click to show)
First, the old type the is the "EK-FC Bridge" and the new one is the "EK-FC Terminal".
Second, you can't mix and match them. The EK-FC Bridge (the ones with all the circles on it) can ONLY be used with the blocks that have the Original CSQ look (the ones with all the circles on it). Since you're going with GPU blocks from the 10x0 series, you'll be using on the EK-FC Terminal type of connectors.
akira749 is offline
