Overclock.net › Forums › Intel › Intel - General › $1766.72 Gaming Build
$1766.72 Gaming Build - Page 2
post #11 of 12
The Antec TP new is an epic PSU. Very reliable, very low ripple and just a lovely piece of equipment, and yes, that would handle your 9800GTX and your 6950 without any problems.
Since you're using your 9800 as a Physx card it will use pretty much no power. I'm also not sure if the 650d is like the 800d and designed as a watercooling case. The 800d is shocking for aircooling.
post #12 of 12
I think I might do a slow upgrade over time with my system... Start with a GTX 480 and work my way up.. Eventually I may get the Asus motherboard and then run the 480 as my primary with the 9800GTX+ for physX. That combination should be able to handle any game for the next while.. And until I get 1080p monitors it may actually be a bit overkill..
i7 7700k ASRock - Fatal1ty Z270 Gaming-ITX/ac Mini ITX L... MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-320...
Hard DriveHard DriveCoolingCooling
Crucial - MX300 525GB 2.5" Solid State Drive Toshiba America Electronic Components Inc X300 ... CRYORIG - C7 40.5 CFM CPU Cooler Thermal Grizzly - Kryonaut 1g 1g Thermal Paste
OSKeyboardPowerCase
Microsoft - Windows 10 Home OEM 64-bit iClever Ultra Slim 3 Color Backlight Aluminum A... Corsair - SF 600W 80+ Gold Certified Fully-Modu... Silverstone - RVZ01B Mini ITX Desktop Case
MouseAudioOther
Logitech - MX Anywhere 2 Wireless Laser Mouse Bose SoundLink Mini Bluetooth Speaker II (Carbon) FLIRC USB (2nd Generation) Universal Remote Con...
OSKeyboardPowerCase
MouseAudioOther
  Back to Forum: Intel - General
