Overclock.net › Forums › Graphics Cards › NVIDIA › 65C Idle?
65C Idle?
post #1 of 17
Is this normal? My card has just the stock cooler, havent noticed that its so high.
Fan is on auto on Afterburner.
Thanks, Sir Overkill
RIGIE
990X 4.5GHz 24/7 GA-X58A-UD9 4X EVGA SC 580 in SLI Dominator GT (3x2Gb)2000
Hard DriveOSMonitorKeyboard
OCZ 120GB SSD/WD 27" 32" Logitech MX 5500
PowerCaseMouseMouse Pad
Antec Quattro 1200W OC Lian-Li PC-P80 Logitech None
RIGIE
post #2 of 17
did you add a second monitor? if so the 2D clocks will run higher than they would normally with 1 monitor.
From your sig, I gather you did. Your video card will run much higher 2D clocks example: 1 monitor 250mhz, 2Monitors 450mhz (just pulled some numbers out of my head) but you get the idea, the actual numbers are around there.
Edited by Killam0n - 5/7/11 at 6:05am
Core
(14 items)
i7 920 D0 @ 4.0Ghz Asus P6X58D-E Diamond XOC 4870/512 @ 800//4400 Corsair 3x4gb DDR1600
2x500GB WD RE2 Raid0 Asus Combo, Asus Combo Corsair H80 Windows 7 Ultimate 64bit
HP 2408h Wide Saitek Eclipse II Corsair HX850W Antec 900 Two
MouseMouse Pad
Logitech Mediaplay Cordless Black as in Dark abyss
Core
(14 items)
MouseMouse Pad
post #3 of 17
Two monitors hooked up will give you temperatures into the 60s for idle. Unhook one and you'll go back to the low 40s.
Xeon E5-1680 V2  R4BE  TITAN X (Pascal)   2666 Dominator Platinum CL10
Hard DriveCoolingCoolingOS
750 NVMe 1.2TB EK HF/rx360/rx120 EK FC/GTs/mcp655 Windows 10 Pro
MonitorPowerCaseAudio
BL3200PT 1600 T2 800d Pro Audio 2.1 + DragonFly Red
post #4 of 17
you should be fine as everyone said when you add a second monitor the 2d clocks run higher. my hd 5850 idles at 63c in a dual monitor set up. i dont use duals very often unless im doing some major cad work
valkyrja
(28 items)
mini destroyer
(17 items)
Intel i7 2600k asrock z77 professional-m evga GTX670 (reference) patriot viper extreme division 4
OCZ Vertex 4 SSD Seagate Momentus  Western Digital My Book ASUS SDRW-08D2S-U
CoolingCoolingCoolingCooling
XSPC EX120 JINGWAY DDC12V PRO 800LPH PUMP swiftech micro res assorted fittings
XSPC RAZA  EK FC670 GTX ACETAL CSQ EK FC670 BACKPLATE XSPC EX120
XSPC EX120 YATE LOON D12SM-12 YATE LOON D12SM-12 YATE LOON D12SM-12
OSMonitorKeyboardPower
Windows 7 Ultimate x64  AOC E2343FK Logitech G110 Corsair AX850
CaseMouseMouse PadAudio
Silverstone ps07 x7 xl-790h Corsair MM200 Pioneer VSX-D914
intel core i7-3615QM apple mac mini 6,1 logic board intel hd 4000 patriot mac series
Hard DriveHard DriveCoolingOS
corsair neutron gtx 240 ssd hitachi apple hdd stock apple cooling osx 10.8.4 mountain lion
asus vs238 apple wired usb keyboard stock apple psu mac mini 6,1 late 2012
MouseMouse PadAudioAudio
apple mighty mouse corsair 200m presonus firestudio presonus audiobox usb 22vsl
Audio
samson resolve A6 studio monitors
valkyrja
(28 items)
mini destroyer
(17 items)
Audio
post #5 of 17
I do have them both plugged in but im only using one monitor.
Its at 66C atm.
Thanks, Sir Overkill.
RIGIE
RIGIE
post #6 of 17
Wow! Time to go to AMD Radeon ref cards..... my Sapphire HD6970 runs at 49C under 100% load with an overclock of 900/1400. Also its on EyeFinity now btw.
Sounds quite warm to be running at 65C on stock clocks. Maybe up the fan speed in MSI Afterburner.
post #7 of 17
Its at 66C atm.
That's definitely not normal...for a single card those are more like load temps. How hot does it get under load?
post #8 of 17
86C was highest on 3Dmark11.
RIGIE
RIGIE
post #9 of 17
I Overclock to 940 core at 1.150 with 85% fan and ran all tests on 3Dmark11 and got max temp of 71.
RIGIE
RIGIE
post #10 of 17
Well that doesn't sound too bad. My 6970 only ran 5 degrees cooler on the 3d mark.
You said you got 86 before, did you drop the volts or something, or was that just the increase in fan? Maybe it's just your fan profile that needed adjusting.
My System
i7 990x @ 4.3ghz HT on Gigabyte X58-OC HD 7970 X 2 24gb @ 2000mhz
500gb ssd/hhd hybrid and 500gb hdd and 1tb ext hdd LG Blu Ray& Asus DVD R/W Windows 7 Hanns-G 28"
It has one 875w Thermaltake Toughpower XT NZXT Phantom in red. It has one
Mouse Pad
My Sofa Arm
My System
Mouse Pad
My Sofa Arm
  Back to Forum: NVIDIA
