Overclock.net › Forums › Benchmarks › Benchmarking Software and Discussion › 18400 3dmark Vantage
post #1 of 8
I have gtx480 and q9450 @ 3.6Ghz
Can i improve this?
Gamming RIG
Intel Q9450 @ 3,65Ghz ASUS Striker II Formula Zotac GTX480 2x2GB RAM G.Skill 1100MHZ
Hard DriveOSMonitorKeyboard
(2) Samsung F3 (2) WD Raptor Windows 7 Samsung 223BW Logitech G15
PowerCaseMouse
Corsair TX750W Antec Twelve Hundred Logitech G5
Gamming RIG
PowerCaseMouse
post #2 of 8
Overclock you gpu I guess. Don't get to caught up in vantage benchmarks my friend. It's not like the Guinness world record.
The BAWS!
(14 items)
AMD Phenom II 955 BE Asus M5A97 EVO Sapphire 6870 Gskill RipJaws DDR3 1600 2x4GB
Western Digital LG super multi lightscribe Corsair H50 with Coolermaster R4 in push/pull Win 7 Ultimate 64bit
23" Acer LED 60hz $8 local computer store brand Corsair 750TX CM 690 II
MouseMouse Pad
CM Sentinel Advance Steel Series
The BAWS!
(14 items)
MouseMouse Pad
post #3 of 8
cpu is holding you back
Gaming Rig
CPUMotherboardRAMOS
4790k @ 4.8GHZ z97 sabretooth mark s 290 Win 7 64bit
KeyboardMouse
Saitek Saitek
Gaming Rig
CPUMotherboardRAMOS
KeyboardMouse
Saitek Saitek
post #4 of 8
If I o.c more the GPU i have artifacs. Yes. i think my cpu limit the potential of my gpu... thanks.
Gamming RIG
PowerCaseMouse
Gamming RIG
PowerCaseMouse
post #5 of 8
Id be happy with that,if you did want more though id look at overclocking that cpu up to at least 4Ghz,although i now thats gona deppend the abillity of your board as thats gona take quite some FSB.
Anyway,get that gpu under water......910 core solid here in anything,920+ for benching,makes a big difference to stability under water.
Le Box of Black
(19 items)
i7 930 Gigabyte X58A-UD7 r2.0 GTX 770 16GB Corsair Vengeance in Triple channel mode ;)
Ocz Vertex 2  Samsung F1  Samsung F3 Samsung F1
Optical DriveOSMonitorKeyboard
Sammie Dvd rw Windows 7 64Bit HZ281HPB 1200p / HP IPS 1080p / Samsung Syncmas... Qpad MK80 (Blue switch), SteelSeries 7G (Cherry...
PowerCaseMouseMouse Pad
HX1000 CM-Stacker 832 Flipped Naos 3200,G5,G400,G400s, G300, Kone+ Razor Destructor and Steelseries Qck
AudioAudioAudio
X-Fi Fatal1ty  ATH-T500 / AH-D510 Samson CO1U PAK Condenser Mic
Le Box of Black
(19 items)
AudioAudioAudio
post #6 of 8
I can o.c to 3,8Ghz stable my CPU but when i do this appear artifacs. Its possible that i need more Watts? (i have tx750).
My Mobo is a Striker II Formula (780i), and my max oc in Q9450 is 4.03Ghz but i had installed 9800GTX+
Gamming RIG
PowerCaseMouse
Gamming RIG
PowerCaseMouse
post #7 of 8
OCing your CPU shouldn't cause artifacts...
post #8 of 8
i know, for this reason i think maybe i need more watts. The comsume of GPU is 400W and my PSU has 750W.
I set the gt480 on 1.125V with afterburner and when the processor is more 3.6Ghz i think the gpu its slower.
Gamming RIG
PowerCaseMouse
Gamming RIG
PowerCaseMouse
