Overclock.net › Forums › Graphics Cards › AMD/ATI › 58850 Crossfire Questions
post #1 of 9
Alright so I'm about to pull the trigger on another 5850 to get a crossfire setup going.
http://www.memoryexpress.com/Product...28266(ME).aspx
That is the one I am looking at right now. My vapor x version only has a slightly higher clock speed than that one so my questions are:
1) Is there any difference in terms if performance between the two? Other than the slightly higher clock speeds?
2) I will be able to overclock my new one to match the speeds of my current one right?
EDIT:
3) When I have both cards in I don't have to do anything special to get a third monitor setup?
4) Is setting up cf hard? Is it just a matter up setting up the connector between the two cards and then downloading the proper drivers?
I will add more questions as I come up with them, and thanks to everyone who helps!
Edited by -relk- - 5/27/11 at 1:51pm
My System
Phenom II X6 1055t @ 3.6GHz 24/7 Asus Crosshair IV Formula x2 5850 Crossfire Patriot Viper II Series 4GB
Hard DriveOSMonitorKeyboard
WD 1TB Windows 7 Samsung SyncMaster 2494SW 24in Logitech G15
PowerCaseMouse
Corsair TX 850W Cooler Master HAF 922 Logitech MX518
My System
PowerCaseMouse
post #2 of 9
when you put more then one gfx card in in sli/crossfire they default to the slower cards speed so the limiting factor would be how high you can get the new card at since it may have ben binned lower then the vapor
also when ocing 2 cards there speeds should be linked if useing msi afterburner to oc there is a check box in they settings to do that for you
bigtanandsexy
(16 items)
1090t oc 4.3 asus crosshair IV his 6950+msi 6950 shaders unlocked 8 gigs G.skill ddr31600
3x wd re4 500gig raid 0, 1 st 7200.12 samsung 830 asus dvd-rw rasa+rx360+coolstream 280
OSMonitorKeyboardPower
win 7 64 37' hdtv leopold antec tp 750 new
CaseMouseAudio
df-85 rat7 essence stx
bigtanandsexy
(16 items)
CaseMouseAudio
post #3 of 9
1. They should be fairly the same except for cooling
2. Yes you can overclock your new one to match the current one
The Laptop
(6 items)
CPUGraphicsRAMHard Drive
Intel i7 2860QM AMD Radeon HD 6770M Corsair Vengence 1600MHz Samsung 840 Pro 256GB
OSMonitor
Mac OS X 10.8 1680 x 1050 anti-glare high resolution
The Laptop
(6 items)
OSMonitor
post #4 of 9
1. Basically the same aside from cooling.
2. Yes, in CCC and MSI AB there's an option to act as if both cards are one and you can overclock them both as if you were overclocking one card.
post #5 of 9
I think we are a couple generations away from seeing a 58850 TBH.
post #6 of 9
Thanks! I knew that the speeds are limited to the slower one but just wanted to make sure.
So when I do overclock, I do so with both at the same time? I guess that makes sense haha
Another quick question, when they are setup in cf, will I be able to hook a third monitor up?
My System
PowerCaseMouse
My System
PowerCaseMouse
post #7 of 9
inb4 clever 58850 com-- Oh nvm
Yuki
(20 items)
Illya
(20 items)
Neptunia
(12 items)
Intel 2500K 5Ghz ASUS P8P67 Pro EVGA 1080 Ti FTW3 G.Skill RipJaws X 2133Mhz 16GB
Hard DriveHard DriveHard DriveCooling
240GB Corsair Neutron GTX RAID0 Samsung 850 Evo 1TB WD Red 8TB Corsair H115i GTX
CoolingOSMonitorMonitor
EK Vardar fans Windows 10 Dell u2713hm Apple Cinema Display
Razer BlackWidow 2013 CoolerMaster V1000 Corsair 760T Artic White Logitech G502 Proteus Spectrum
Mouse PadAudioAudioAudio
CoolerMaster Swift-RX XL ASUS Xonar DX Schiit Magni Sennheiser HD650
Intel Core i7 Skylake-E X190 Nvidia Titan Volta 32GB 3200Mhz DDR4
Samsung 960 Pro 512GB Samsung 850 Evo 1TB 8TB WD Red Corsair H115i GTX
Ducky Shine CoolerMaster V1000 Corsair 760T Artic White Logitech G502
CoolerMaster Swift-RX XL Asus Xonar DX Schiit Magni Sennhesier HD650
Core i5 6600 3.3Ghz Asus Z170M Pro AMD RX460 G.Skill 16GB 2133Mhz
Samsung 850 M.2 256GB Windows 10 Dell S2817Q 4K Ducky Shine 3
PowerCaseMouseMouse Pad
CoolerMaster Vanguard 450W BitFenix Phenom Logitech G700S CoolerMaster Swift-RX
Yuki
(20 items)
Illya
(20 items)
Neptunia
(12 items)
post #8 of 9
When you're overclocking there's an option to act is if both cards are ONE card, that way you can overclock both cards as if they were one. LOL, it's a mouthful of words, but that's really how it is.
post #9 of 9
yea you can do eyefinity with 2 cards. also you can overclock them seperatly.
Core i7 5930k MSI X99S SLI GTX 1080 32GB Crucial DDR4
Hard DriveHard DriveCoolingCooling
(3x) Crucial 256GB (768gb RAID0) WD 3TB EK Supremacy EVO + D5 Vario GT-AP15
CoolingMonitorMonitorKeyboard
2X HWLABS GTX360 (2x) 1440p QHD PLS MicroBoard 40" 4k MVA Corsair K70 RGB
PowerCaseMouseAudio
Corsair RM1000 Custom Build Logitech G900 Yamaha RX-V465 + 5.1 Surround
PowerCaseMouseAudio
  Back to Forum: AMD/ATI
