Overclock.net › Forums › AMD › AMD CPUs › 955 oc
955 oc
post #1 of 9
Anyone else think this is the norm for c3 stepping chips?
4.2ghz on 1.4?
Its stable so far.
My ram is 800mhz and northbridge at 2.0ghz
Behind the Curve
(16 items)
i5-4570 GA-Z87-D3H MSI GTX 980ti Gaming 6G Adata green special DDR3 1333 4x 4GB (16GB kit)
Seagate Barracuda Samsung DVD+RW CM 212 Windows 8.1 pro 64bit
MonitorMonitorKeyboardPower
LG 34" 21:9 LG 23" 16:9 DELL!!! Corsair TX750w
CaseMouseMouse PadAudio
CM 692 with window Razer-LACHESIS Razer-Sphex Pad Logitech 5.1 surround
Behind the Curve
(16 items)
post #2 of 9
if it is stable yes, c3 chips can run the northbridge at 2800ish
Wet Willy
(17 items)
Oold man 555
(11 items)
i7 920 @4.217 1.24 v's 24/7 Asus p6t6 ws Revolution (full water blocks) GTX 480 SLI @867-1734 samsung 30nm at 2040mhz. 8-9-9-26 1.54v's
Hard DriveOptical DriveCoolingCooling
OCZ Agility 3 RAID0 lite on dvd burner Raystorm Danger Den 480 Full copper (paralleled)
OSMonitorMonitorKeyboard
Dual boot, Windows7 64bit/Linux ubuntu64bit 1hpw2207h1680/1050  Sharp 60" LED 120hz s510
PowerCaseMouseAudio
Ultra 1600w X4 NZXT, Tempest EVO logitech s510 combo Harmon Kardon AVR245
Phenom II X4 B55 m4n82 deluxe ghetto gtx 460 patriot viper 1066
some crap sata dvd thermal take big typhoon windows 7 ultimate
MonitorPowerCase
hp 2207h ultra lsp 750watt cooler master elite
Wet Willy
(17 items)
Oold man 555
(11 items)
PowerCaseMouseAudio
MonitorPowerCase
post #3 of 9
Wow. Thats impressive. Are U stable at those clocks? And as asustweaker wrote; U should up the Nb speed as high as U can(2600-3000).
Rig
(14 items)
Fast one! Asus Good one! Yeah got sum of that...
Hard DriveCoolingOSMonitor
one of those 2,5 inch No good without it... Prolly the newest Check!
KeyboardPowerCase
Seems like it... 1000W`ish Huge, but not happy about it
Rig
(14 items)
KeyboardPowerCase
post #4 of 9
I have ran blend 15 mins and both large fft and small fft.
I am going to run prime all night to see if it is for sure.
If it is I may give the NB a boost too. Im not completely sold on it. But its looking good so far.
Behind the Curve
(16 items)
Behind the Curve
(16 items)
post #5 of 9
Looks good but 15mins is not enough to call stable. Aim for at least 6 hours or more. Make sure temps dont go over 62c or 55c so you have a little head room.
Fear The Badger
Phenom II 955BE 4.2Ghz@1.44v Asus M4A89GTD PRO MSI GTX460 Hawk 910/1820/1950 2x2GB G.Skill Trident ddr3 1600
Hard DriveOptical DriveOSPower
WD Blue 500GB LG Windows 7 Ultimate X64 Corsair VX550
Antec 902 V3 Black
Fear The Badger
Antec 902 V3 Black
post #6 of 9
15 min is far from stable. The NB gets smacked tough around 3 hrs on prime95. The longer the better. Most disagree on how long but lite prime95, go to bed and see in the morning if it passes. 955 C3's top out at 4.1GHz or so stable with good cooling. Good luck!
My System
Core i7 930 overclocked 4.5Ghz 24/7 stable Gigabyte X58-UD3R 2 x Radeon 6970 6G Kingston Hyper X 1600MHz
OCZ Vertex 2 60G Asus Win 7 64 bit Asus 24
PowerCaseMouse
Nexus 1100W Tech Statioin Logitech
My System
PowerCaseMouse
post #7 of 9
Well, update.
Im at 1.42v and 12hrs stable. So, not to bad i dont guess. Not a record or anything but i am well pleased.
I shall now start with NB clocks. Any suggestions on a good Volt starting point for a Northbridge if I do have to bump the volts? and a max would be helpful.
I assume there is a general rule. Or does it just base itself off of what type of Motherboard i have?
Behind the Curve
(16 items)
Behind the Curve
(16 items)
post #8 of 9
Originally Posted by Anti!! View Post
Well, update.
You using the CPU fan from your sig rig?
post #9 of 9
Yeah.
Behind the Curve
(16 items)
Behind the Curve
(16 items)
  Back to Forum: AMD CPUs
