Overclock.net › Forums › Intel › Intel CPUs › 124 BSOD sandy bridge
post #1 of 9
hello, i have a problem: every now an then when i got a loading screen or when i kill a task, or close some big apps i get this bluecreen, its definitly not a vcc issue, since i already gave it +0.015v to the configuration i used to confirm stable with prime, ibt, occt, many games and benchmarks
maybe a VCCIO issue? my ram is on stock settings atm, vccio is at 1.125v iirc
2500k 4.7ghz @1.39v ASUS P8P67 pro rev 3.0 Sapphire 6950 950/1375@1.160v unlocked 2x4gb g.Skill Ripjaws X @2133 mhz
2x F3 1TB raid0 Sony Optiarc AD-7260S Windows 7 Professional 64 bit Acer LED S1 S231HLbd, 23"
Cherry eVolution STREAM XT Corsair 650 tx v2 HAF922 CM Storm Sentinel Advance
Mouse Pad
Steelseries QcK+
Mouse Pad
Steelseries QcK+
post #2 of 9
Go here it explains what this stop code means.
Jango (Main Rig)
(23 items)
Edward (HTPC)
(16 items)
Intel Core i7-4790 MSI ATX LGA 1150 Z97 PC MATE mobo EVGA GeForce GTX 1060 SC GAMING 16GB
OCZ Agility 4 (OS) 1TB Hitachi (Data & Apps) 1TB Hitachi (Movies & other Multimedia) 750GB
Optical DriveCoolingCoolingCooling
DVD±RW / ASUS USB 2.0 8x Slim external DVD Burner Cooler Master Hyper T4 NZXT Sentry Mix COOLER MASTER SickleFlow 120mm x2
OSMonitorMonitorMonitor
Windows 10 Pro 64bit ASUS VS247H-P 23.6"  ASUS VH236H 23"  HP 27" 2560x1440
Logitech Illuminated Keyboard Corsair Professional Series HX850W CM Storm Trooper Razer Tron
Mouse PadOtherOther
XTRAC Pads Ripper XL Rosewill Red USB 2.0 7 Port Hub With Power Adapter Creative HS-1000 Fatal1ty Gaming Headset
AMD Phenom II X4 920 2.8GHz Socket AM2+ 125W Qu... ASRock A780GXE/128M AM2+/AM2 AMD 780G ATX ATI Radeon HD 4670 G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1...
RAMHard DriveHard DriveCooling
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1... Hitachi 1TB 7200 RPM SATAII 3.0Gb/s Samsung 250GB 7200 RPM Enermax ETS T-40 T.B. SILENCE
OSMonitorPowerCase
Windows 8.1 Pro 64 bit 47" Sony TV RAIDMAX HYBRID 2 530W Custom Wood Table
Jango (Main Rig)
(23 items)
Edward (HTPC)
(16 items)
Mouse PadOtherOther
OSMonitorPowerCase
post #3 of 9
sry but this doesnt help me at all
1) Ensure that none of the hardware components are overclocked. Hardware that is driven beyond its design specifications - by overclocking - can malfunction in unpredictable ways.
srsly?
i know that it is because the overclocking, but not what i need to change
Mouse Pad
Steelseries QcK+
Mouse Pad
Steelseries QcK+
post #4 of 9
Disable power savings and it'll most likely work.
My System
Core i7-2600K @ 4.5 GHz w/ 1.4 V Gigabyte GA-P67A-UD3P-B3 MSI GTX 570 Twin Frozr III PE TeamGroup 1333 Mhz CL9 2x4
Samsung F3, F1, T166 Samsung Win 7 BenQ 24"
PowerCase
Sapphire FirePSU 625 W Fractal Design R3
My System
PowerCase
post #5 of 9
0124 usually indicates low vcore or low QPI/VTT(1st Gen i7)
EDIT:
0x101 = increase vcore
0x124 = increase/decrease vcore or QPI/VTT...have to test to see which one it is
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1E = increase vcore
0x3B = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
Le Box of Black
(19 items)
i7 930 Gigabyte X58A-UD7 r2.0 GTX 770 16GB Corsair Vengeance in Triple channel mode ;)
Ocz Vertex 2  Samsung F1  Samsung F3 Samsung F1
Optical DriveOSMonitorKeyboard
Sammie Dvd rw Windows 7 64Bit HZ281HPB 1200p / HP IPS 1080p / Samsung Syncmas... Qpad MK80 (Blue switch), SteelSeries 7G (Cherry...
PowerCaseMouseMouse Pad
HX1000 CM-Stacker 832 Flipped Naos 3200,G5,G400,G400s, G300, Kone+ Razor Destructor and Steelseries Qck
AudioAudioAudio
X-Fi Fatal1ty  ATH-T500 / AH-D510 Samson CO1U PAK Condenser Mic
Le Box of Black
(19 items)
AudioAudioAudio
post #6 of 9
not enabled.
Mouse Pad
Steelseries QcK+
Mouse Pad
Steelseries QcK+
post #7 of 9
adding more vcore got rid of the 124 BSOD for me
My System
i5 2500k @ 4.5GHz (1.3vcore) Gigabyte UD4 B3 Sapphire Radeon 6850 4GB G Skill 1333 "Ripjaws"
Hard DriveOSMonitorPower
Hitachi Deskstar 500 (SSD soon) Win7 x64, Ubuntu 32" Samsung LED TV Corsair CX600w
650D
My System
650D
post #8 of 9
124 is vcore. With sandy bridge it is almost always vcore. On previous generations it was qpi/vtt.
And I would NOT disable power saving features. I would leave those enabled. Asus p67 boards were designed to have power saving enabled during overclocking.
If you had a gigabyte board you could turn them off without any problems.
My System
2600k p8p67 deluxe reference gtx 680 Ripjaws(blue)1866, 8-9-8-24-2t
c300, 2X WD CAVAIAR BLACK 640GB RAID 0 LG Bluray/Dvd Rewriter 7 Ult Gateway 24" lcd 1920x1200
Lycosa Corsair 750w tx Cooler Master HAF 932 black g9
My System
post #9 of 9
well its definity not vcore (even abourmously high vcore voltages for a 4.7 ghz overclock didnt help), I increased the VCCIO to 1.15v now, seems to run fine, loaded and unloaded a lot of programs etc (seems reasonable that its a ram controler issue if it only does that while I load or unload a huge application)
Edited by brolly - 6/16/11 at 2:24pm
Mouse Pad
Steelseries QcK+
Mouse Pad
Steelseries QcK+
  Back to Forum: Intel CPUs
