Overclock.net › Forums › AMD › AMD - General › 925 oc question
925 oc question
post #1 of 8
hi all, just built a super leet gaming rig for my friend:
Keyboard:G510 Logitech
mouse: Razer Naga
mouse mat:razer golitahus
speaker:Logitech 2.1
Monitor:21.5' acer HD
SSD:crucial M4 64Gb
HD:Seagate 500Gb 7200
MB:Asus M488TD-EVO
PSU:Corsair 650TX
GPU:Sapphire 6770
CPU: Phenom II x4 925
CPU cooler:Hyper 212+
Ram:2x2Gb G.SKILL Ripjaws ddr3 2000
case: AZZA toledo 301
lots of blue led fan in extra^^
so far its an awesome build, at stock it 2.8Ghz(14x200) @ stock volt(1.36) and my ram was at 1333, so i got max fsb of 295 keeping total clock of 2.8ghz, then raised multiplier one step at a time. BTW I WILL NOT PLAY WITH VOLTAGE, ALL MY VOLTAGE WILL STAY @ STOCK!! I got some problem really fast(around 295x11.5) so i lowered my fsb to 280, and got stable x13 multi(for a total clock of 3.65Ghz). i get very nice temp(46 degree under load and room temp is 30 degree, its all in the airflow^^), i am very happy with this oc, 3.6ghz is enough for me and with 280 fsb i got my ram to 1860 which is ok.
But i was wondering about something. i open speedfan and cpuz before launching prime95, and cpuz shows core voltage palying around 1.38 and the moment i start prime95 it stabilize the vcore at 1.356. Everything works great and stable, no prime95 crash, but i was wondering why does my vcore drops under load?
GW2 Special
(16 items)
Redstroyer
(14 items)
Phenom II X2 555(unlocked to X4 B55) Biostar ta870u3+ 6950HD msi twin frozr OC 2x2gb g.skill ripjaws ddr3 1600
OCZ Solid 3 Lg combo with IDE to sata adapter H50 win 7 x64
dynex hdtv 22''(HD)/philips 19''(VGA) k260(logitech wireless combo) corsair 650tx azza orion
MouseMouse Pad
m210(logitech wireless combo) INFOREM custom mouse pad
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
post #2 of 8
It might just be a misread. CPU-Z used to read my 945 at 1.175v constantly. The 925 has a locked multi, right? You might be surprised by how far it can OC; I used to be able to hit 4.2GHz with my Phenom II 945 (granted at ~1.5v). But if you don't want to raise the Vcore, I respect that.
Budget
Core i5 7600K @ 4.8GHz Turbo ASUS PRIME Z270-K Sapphire RX 580 8GB Nitro+ 16GB Corsair LPX DDR4 3000
Hard DriveCoolingMonitorKeyboard
Crucial MX300 525GB M.2 CRYORIG H7 ASUS VE258Q Thermaltake Poseidon Z
PowerCaseMouseMouse Pad
Corsair TX650M Thermaltake F31 Tempered Glass Razer DeathAdder Chroma SteelSeries QcK+
Audio
Corsair VOID Wireless
Budget
Audio
post #3 of 8
Thats normal.
I'm not exactly sure about the science behind it, but at idle, there is basically 'power on tap' thats not being used and when under load, your pc uses more electricity causing the core voltage to drop. Something like that, I'm sure someone else will be able to explain it better..
MKG-Cosmos II
(14 items)
i7 920 DO oc'd to 4.25Ghz EVGA 3-way Sli Classified 2x480 SLI 3x2g Corsair CMG6GX3M3A2000C7
80g Intel ssd, 2x300g raptors (0), 2x1 TB RE3 (0 Pioneer Blu-Ray burner, 22x dvd burner custom loop Windows 7 64bit
LG W3000H, dell ultra-sharp 24" Ducky 'OCN' with brown hx1000 Cosmos II
MouseMouse Pad
mionix naos 5000 steelseries SX
MKG-Cosmos II
(14 items)
MouseMouse Pad
post #4 of 8
ok, anyway i could see the real vcore? another program? does it change something, i mean could it be dangerous or anything?
edit:thx and rep+ both
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
post #5 of 8
AMD Overdrive or even RealTemp (depending on your motherboard) would work. I presume AMD Overdrive would be the most accurate. In my experience, CPU-Z is actually one of the least accurate diagnostics programs.
Budget
Audio
Budget
Audio
post #6 of 8
ok ill try it, but no hint if there is a possibility to harm the system?
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
post #7 of 8
It's not dangerous in the slightest. It may have something to do with power saving features also. If your stable like stated above, I wouldn't worry about it at all and either call it a day, or try to overclock more
MKG-Cosmos II
(14 items)
MouseMouse Pad
MKG-Cosmos II
(14 items)
MouseMouse Pad
post #8 of 8
thx, and i did disable the cool'n'quiet feature. im glad its not dangerous
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
GW2 Special
(16 items)
Redstroyer
(14 items)
MouseMouse Pad
  Back to Forum: AMD - General
