Overclock.net › Forums › Graphics Cards › AMD/ATI › 5770
5770
post #1 of 3
I got through my display port adapter today.
Connected DP > DVI TO VGA CONVERTER > MONITOR , but my monitor doesn't work.
What am I doing wrong, i've tried two monitors changed the adapter, changed the cable.
If someone turns around and says my monitor needs to be display port able im gonna go ape!
Intel Core i7 920 D0 @ 4.2 Gigabyte GA-EX58-UD3R v1.6 ATI Radeon HD 5700 Series 6GB DDR3 1600MHz Ripjaw Series Triple Channel kit
WDC WD10EARS-00Y5B1 & WDC WD25 00JB-00REA0 ASUS DRW-24B1ST Windows 7 x64 Samsung SyncMaster 2243NW/2243NWX 22" LCD x2
Microsoft Comfort Curve Keyboard 2000 850W Enermax Revolution 85+ Modular Coolermaster Cosmos S Microsoft Comfort Optical Mouse 1000
Mouse Pad
COREPAD CC26120 C1 Large Cloth
Mouse Pad
post #2 of 3
It is a bit hard to understand what exactly are you doing. As far as I understand you are using displayport -> DVI converter and then attach to that DVI port a DVI -> VGA converter ?
If this is true then the possible issue might be that your displayport -> DVI converter puts out only a digital signal and DVI-> VGA converter does not work as a result as VGA is analog signal.
However, you can use a VGA monitor in displayport just fine even if rest of your slots already have monitors in them with an active displayport->VGA converter. For example I myself are atm using a cheapish one ordered from ebay (link to the item http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT) and I can confirm it does work for Eyefinity (2x displays in DVI 1x in displayport->VGA all working and being able to make three monitor eyefinity).
A passive converter is also possible, is about 5$ cheaper but does not work if you populate both of your DVI slots.
Hope this helps.
Kohver v.4
(25 items)
Kohver v.3
(21 items)
Soliton
(23 items)
Intel Core i7 3820 X79-UP4 Gigabyte 390X G1 Club3D 7870 Eyefinity 6
64 GB Barracuda 3 TB WD Green 3 TB Crucial M4 256 GB
Hard DriveHard DriveHard DriveCooling
Crucial M4 64 GB Barracuda 4 TB Corsair LE 480HB Sythe big shuriken rev B
CoolingCoolingCoolingOS
Nexxos 280mm radiator DC-LT Alphacool GPX 390M04 Windows 7 Pro 64 bit
MonitorMonitorMonitorMonitor
DELL U2311H (x3) DELL U2312HM (x2) 9.7'' 2048x1536 (x3) IPAD3 retina Asus PB287Q 4K
CM Quickfire TK (red) Corsair AX-1200i Significantly modded Jupiter .. something alumi... Logitech G700s
Mouse Pad
3M Ergonomic
Hard DriveHard DriveCoolingOS
Crucial M4 64 GB Barracuda 4 TB Sythe big shuriken rev B Windows 7 Pro 64 bit
CM Quickfire TK (red) Corsair AX-1200i Modded Sharkoon VS-3 Logitech G700s
Mouse Pad
3M Ergonomic
Intel Core i7 3820 X79-UP4 Sapphire 7950 FleX OC XFX 6770 Eyefinity 5
GraphicsRAMHard DriveHard Drive
Club3D 7870 Eyefinity 6 64 GB Samsung 750 GB F3 Barracuda 3 TB
WD Green 3 TB Crucial M4 256 GB Crucial M4 64 GB Barracuda 4 TB
CoolingOSMonitorMonitor
Custom loop Windows 7 Pro 64 bit DELL U2311H (x3) DELL U2312HM (x2)
MonitorMonitorKeyboardPower
9.7'' 2048x1536 (x3) IPAD3 retina Asus PB287Q 4K CM Quickfire TK (red) Corsair AX-1200i
CaseMouseMouse Pad
Modded Chieftec Smart WH-02B-B-OB Logitech G700s 3M Ergonomic
Kohver v.4
(25 items)
Kohver v.3
(21 items)
Soliton
(23 items)
Mouse Pad
3M Ergonomic
Mouse Pad
3M Ergonomic
CaseMouseMouse Pad
post #3 of 3
Hi est1984. As Carniflex has said it may well be the way you are currently connecting the monitor to the graphics card. It is obviously recommended to use a pure Display Port connection from card to display, but if this isn't possible using an active adapter should be no problem. However, if you are using a DP adapter to another adapter to the monitor, this may cause a problem. If possible try just using the DP adapter directly from card to display.
Thanks,
Harry @ Videocardshop.
  Back to Forum: AMD/ATI
